Charging and Power Hub 1x AC Power and 2x USB-A Table-Mounting Bracket. Provide power and charging wherever it's needed. Install the power outlet module in or under a table, workbench, desk or lectern to keep your devices charged. This conference table power hub adds convenient access to an AC outlet and two USB charge ports in your boardroom, classroom or huddle space.
Conveniently Power and Charge Devices
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, lectures and conferences, you may need access to power when your battery is running low or a meeting is running long.
Providing several conference table power outlets, this tabletop power hub makes it easy to power a laptop using the AC power outlet, and charge phones and tablets using the 2.4 amp USB ports.
Customize to Your Exact Needs
Architectural connectivity is quickly becoming the trend when designing a boardroom or huddle space. StarTech.com power modules let you:
Customize power and charging according to the specific needs of your space
Install in easy-to-access locations
You can install this power module as a standalone solution using the supplied table-mounting bracket. Or, you can install it as an accessory in a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately). The table boxes provide a sleek multi-purpose connectivity solution that reduces cable clutter and can be customized to your needs.
MOD4POWERUK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, lectures and conferences, you may need access to power when your battery is running low or a meeting is running long. Providing several conference table power outlets, this tabletop power hub makes it easy to power a laptop using the AC power outlet, and charge phones and tablets using the 2.4 amp USB ports. -
Architectural connectivity is quickly becoming the trend when designing a boardroom or huddle space. StarTech.com power modules let you: • Customize power and charging according to the specific needs of your space • Install in easy-to-access locations You can install this power module as a standalone solution using the supplied table-mounting bracket. Or, you can install it as an accessory in a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately). The table boxes provide a sleek multi-purpose connectivity solution that reduces cable clutter and can be customized to your needs. MOD4POWERUK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Power Outlet Module for Conference Table Connectivity Box - surface mount distribution box
- Product Type
- Surface mount distribution box - USB X 2, power BS1363
- Placing / Mounting
- Desk mountable
- Package Content
- Mounting bracket, power cable
- Localisation
- United Kingdom
- 2-year warranty
- Product Type
- Desk mountable
- Package Content
- Localisation
- United Kingdom
Cabling & Wiring
- Connector Provided
- 1 x power BS 1363 female , 2 x 4 pin USB Type A (power only) female
- Limited warranty - 2 years
StarTech.com 0.5m Micro USB Cable A to Micro B | In Stock | £2.42 |
StarTech.com 3m Micro USB Cable M/M - USB A to Micro B | In Stock | £6.32 |
StarTech.com 2m BS-1363 to C13 Y-Cable | In Stock | £8.44 |
