Power two devices at once from a single power outlet, perfect for dual-monitor setups. This C13 Y-cable lets you plug multiple devices into a single power outlet, to maximize the space on your power strip, surge protector or wall outlet. It's perfect for setting up dual-monitor workstations.
The cable length from the Y-split is 47 cm on each side. This gives you an extended reach for connecting to two monitors securely, without placing a strain on the cable.
The power-splitter cable can also be used for connecting a monitor and computer to the same outlet or any two devices that have a C13 power connection.
The PXT101YUK is built to exact specifications and is fully tested to ensure maximum performance.
 - StarTech.com 6ft (2m) UK Computer Power Cable Y Splitter, 18AWG, BS 1363 to 2x C13 Power Cord, 10A 250V, Replacement AC Power Cord, Monitor Power Cable, BS 1363 to 2x IEC C13 Kettle Lead - PC Power Supply Cable - power splitter - BS 1363 to power IEC 60320 C13 - 1.8 m
 - Power splitter
 - Service Vacuum Thermoplastic (SVT) jacket
- Length
 - 1.8 m
- Localisation
 - United Kingdom
- Connector
 - Power BS 1363 - male
- Connector (Second End)
 - 2 x power IEC 60320 C13
- Rated Voltage
 - AC 250 V
- Rated Current
 - 10 A
 - Black
 - Limited lifetime warranty
 - Power splitter
- Jacket Material
 - PVC
- Rated Voltage
 - AC 250 V
- Rated Current
 - 10 A
- Length
 - 1.8 m
 - Black
- Localisation
 - United Kingdom
- Connector
 - RoHS
                        StarTech.com 6 ft Standard UK Computer Power Cord | In Stock | £6.64 |
                        StarTech.com 3m UK Computer Power Cord - 3 Pin Mains Lead - C13 to BS-1363 | In Stock | £6.11 |
                        StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £135.75 |
                        StarTech.com Monitor Mount - USB Passthrough | In Stock | £157.69 |
                        StarTech.com Dual Monitor Mount - Stackable | In Stock | £212.26 |
                        StarTech.com Dual Monitor Stand | In Stock | £82.80 |
