USB Type-C Display Adapter 4K 60Hz Built-In Flex Cable Mac & Windows . This compact USB-C to Mini DisplayPort adapter offers an ultra-portable solution for connecting your USB Type-C laptop or device to a 4K mDP monitor or display. The adapter is equipped with a removable, quick-connect keychain ring that easily attaches to your laptop or projector bag, maximizing portability.
Perfect Travel Companion
This lightweight USB-C to Mini DP adapter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD (Bring Your Own Device) applications at the office or road warriors who need to connect on the go.
It's the perfect solution for:
Delivering high-resolution presentations while in the office or traveling
Connecting your smartphone or tablet to a Mini DisplayPort monitor
Hot-desking environments
Keep Your Adapter with You
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in 1.3" flex cable that has a folding design, adding to the compact form factor.
Plug-and-Play Connectivity
To ensure a hassle-free connection, this video adapter works with all your Mac and Windows USB Type-C devices and is also compatible with Thunderbolt 3 . It requires no additional software or drivers, supporting true plug-and-play connectivity.
CDP2MDPFC is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Perfect travel companion
This lightweight USB-C to Mini DP adapter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD applications at the office or road warriors who need to connect on the go. -
Keep your adapter with you
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in flex cable that has a folding design, adding to the compact form factor.
- StarTech.com Compact USB C to Mini DisplayPort Adapter, 8K 60Hz/4K USB-C to mDP 1.4 Video Converter w/Keychain Ring, USB Type-C DP Alt Mode (HBR3 HDR DSC) to mDP Monitor, TB3 Compatible - USB-C Keychain Adapter (CDP2MDPFC) - video adapter - 24 pin USB-C to Mini DisplayPort
- Video adapter
- 4K support, keychain design, 7.1 audio channel support
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- Mini DisplayPort - female (output)
- Displayport 1.2/Thunderbolt 3
- Black
- 3-year warranty
- Video adapter
- Black
- Connector
- Displayport 1.2/Thunderbolt 3, RoHS, REACH, FCC
- 3-year warranty
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.28 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.35 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.14 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £21.05 |
