StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 6LC0WS00 Mfr#: MDP2DPMM6
More than 50 In Stock
£9.27 ex VAT
£11.12 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM6 6ft Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
  • High-quality connectivity
    This 6 ft Mini DisplayPort to DisplayPort 1.2 cable offers a direct connection to ensure reliable signal transmission between your devices. With its latching DisplayPort connector, it provides a secure connection that won't accidentally disconnect, ensuring uninterrupted viewing.
  • Versatile compatibility
    Designed to be compatible with both Mac and PC, this adapter cable offers a versatile solution for connecting a Mini DisplayPort source to a DisplayPort display. Whether for work presentations or home entertainment, this cable supports a wide range of applications.
  • Superior video quality
    Supporting resolutions up to 4K x 2K UHD, the cable delivers crystal-clear video quality. The nickel-plated connectors not only ensure a solid connection but also maintain the integrity of the signal to provide a high-quality visual experience.
StarTech.com 6ft (2m) Mini DisplayPort to DisplayPort 1.2 Cable, 4K x 2K UHD Mini DisplayPort to DisplayPort Adapter Cable, Mini DP to DP Cable for Monitor, mDP to DP Converter Cord - Latching DP Connector - DisplayPort cable - 1.8 m
DisplayPort cable
Latched
Length
1.8 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: BOX4HDECP, CDP2DP, CDP2DP14B, CDP2DPW, CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DP2MDPMF3, DP2MDPMF6IN, DPBOOST, HD2DP, MDPEXT3, SP123DP, SV231DPU, SV231DPUA, SV431DPDDUA2, SV431DPUA2, TB2DOCK4K2DP
DisplayPort cable
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Latched
Length
1.8 m
Connector
20 pin DisplayPort - male
RoHS
6LC0 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
6LC0 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.07
6LC0 StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £9.68
6LC0 StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £16.12
6LC0 StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.14
6LC0 StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.66
6LC0 StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £21.97
6LC0 StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter In Stock £63.29
