Your basket is empty
StarTech.com PCI-X to x4 PCI Express Adapter Card
Quicklinx: 7P0ZWS00 Mfr#: PCIX1PEX4
The PCIX1PEX4 PCI-X to x4 PCI Express Adapter lets you install a low profile/half-height x4 PCI Express card into a full height PCI-X (3.3V, 64-bit) slot on a server or other high-end motherboard. With a physical x16 PCI Express female slot connector, the PCI-X to PCIe adapter card accepts all types of x16/x8/x4/x1 physical PCI Express cards (maximum speed of x4), allowing an older system to run the newest cards.
StarTech.com PCI-X to x4 PCI Express Adapter Card - riser card
Riser card
4 cm x 16.4 cm x 2 cm
41 g
1 year warranty
Riser card
4 cm
16.4 cm
2 cm
41 g
Expansion Slots
1 (total) / 1 (free) x PCI Express x4
Compatible Slots
1 x PCI-X
FCC, RoHS
Limited warranty - 1 year , Technical support - lifetime
-40 °C
85 °C
