StarTech.com PCI Express x4 Left Slot Riser Adapter Card with 7cm Flexible Cable
Quicklinx: 7VXQWS00 Mfr#: PEX4RISERF
The PEX4RISERF x4 to x4 PCI Express riser adapter card features a flexible cable that lets you install a PCI Express (x4/x1) card away from the system motherboard in a 1U rackmount or small form factor chassis, overcoming limitations created by having to mount expansion cards directly in a motherboard expansion slot.
StarTech.com PCI Express x4 Left Slot Riser Adapter Card with Flexible Cable - riser card
Riser card
10 cm x 17.9 cm x 1.5 cm
35 g
Power Provided
Riser card
10 cm
17.9 cm
1.5 cm
35 g
Expansion Slots
1 (total) / 1 (free) x PCI Express x4
Compatible Slots
1 x PCI Express x4
RoHS
Limited warranty - 2 years , Technical support - lifetime
60 °C
