Convert and extend a Gigabit Ethernet connection over Multimode LC fiber with remote management capabilities. The ET91000LCOAM Managed Fiber Media Converter lets you extend a Gigabit Ethernet connection over Multimode LC fiber, with the added benefit of remote management capabilities.
Compliant with 802.3ah OAM (Operations, Administration & Management), this managed media converter incorporates an easy-to-use web interface for operation, administration and maintenance, enabling you to quickly determine the location of failing links and the fault conditions without sending service personnel to the physical location of the device.
An effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the Ethernet to fiber converter supports full Gigabit speeds at distances of up to 550m (1804ft) through the installed Multi-Mode LC SFP. The converter also features an all-steel chassis, for durability in harsh environments.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable MSA-compliant SFP slot.
- StarTech.com Multimode (MM) LC Fiber Media Converter with SFP - OAM Management - 802.3ah Compliant - Gigabit Ethernet - 550m - 850nm (ET91000LCOAM) - fibre media converter - 1GbE
- Fibre media converter - RJ-45 / LC multi-mode
- Form Factor
- External
- Cabling Type
- 1000Base-LX, 1000Base-SX, 1000Base-TX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- 9.5 cm x 16 cm x 2 cm
- 620 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- Status Indicators
- Port status, power
- Auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3ah
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
- MTBF
- 65,000 hour(s)
- FCC, RoHS
- Power Device
- External power adapter
- 9.5 cm
- 16 cm
- 2 cm
- 620 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
- Designed For
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £40.09 |
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £147.04 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £145.25 |
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £308.76 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £23.89 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £66.05 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £179.13 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.72 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.89 |
