Convert and extend different networks over a Gigabit fiber cable connection up to 550m / 1804 ft.. This fiber media converter offers an easy, cost-effective way to extend your network over Gigabit fiber. It is equipped with a multi-mode transceiver which converts a copper RJ45 Ethernet connection to Gigabit fiber to extend your network over longer distances or connect workstations to switches. The converter provides a powerful extended networking solution for campuses, businesses, government facilities, stadiums, or other areas requiring network access.
The Gigabit Fiber Media Converter provides a cost-effective and dependable solution for shorter range network extensions. It connects an Ethernet network to remote devices over a fiber backbone, with a 550m range on the fiber optic interface. The media converter has a durable metal housing, engineered to deliver long-lasting performance.
Fully compatible with 10/100/1000Base-T Ethernet networks, the fiber media converter supports auto negotiation to bridge different speed networks and devices to a Gigabit fiber network. It provides versatile connectivity to your existing networks and devices, allowing you to maximize the usage and performance of legacy equipment.
The multi-mode transceiver is removable, giving you the flexibility to change your transceiver in the future to meet your networking needs.
The unmanaged fiber media converter has a standalone design with simple plug-and-play set-up to ensure fast and easy installation. Compact in size, the converter gives you flexible installation options - including a wall mounting option to save space.
- StarTech.com Multimode (MM) LC Fiber Media Converter for 10/100/1000 Network - 550m - Gigabit Ethernet - 850nm - with SFP Transceiver (MCM1110MMLC) - fibre media converter - 10Mb LAN, 100Mb LAN, 1GbE
- Fibre media converter - RJ-45 / LC multi-mode
- Form Factor
- External
- Cabling Type
- 10Base-T, 1000Base-LX, 1000Base-SX, 100Base-TX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- Max Transfer Distance
- 550 m
- Power
- AC 120/230 V
- 7 cm x 2.6 cm x 9.7 cm
- 200 g
- 2-year warranty
- Designed For
- P/N: SVA5N3NEUA
- Form Factor
- External
- Brown
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 850 nm
- 550 m
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), Link Fault Pass Through function (LFP), Jumbo Frames support, metal housing
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab
- 1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2
- MTBF
- 50,000 hours
- FCC, RoHS, MSA
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 5 Watt
- 7 cm
- 2.6 cm
- 9.7 cm
- 200 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Designed For
- P/N: SVA5N3NEUA
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £155.00 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - ST | In Stock | £18.35 |
StarTech.com Fiber Media Converter - Open | In Stock | £44.55 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £69.61 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £188.81 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.22 |
StarTech.com USB 3 Fiber Converter Open SFP | In Stock | £192.70 |
StarTech.com USB C to Fiber Optic Converter | In Stock | £197.91 |
StarTech.com Fiber to RJ45 Media Converter | In Stock | £115.71 |
