StarTech.com Multiport Adapter HDMI/VGA
Quicklinx: GLR7WS00 Mfr#: DKT30CHVSDPD
Device Type: Tablet, Laptop, Macbook, Other
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
Hurry, only 2 left in stock!
£33.78 ex VAT
£40.53 inc VAT
This USB-C multiport adapter supports 4K 30Hz HDMI or 1080p VGA and turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI or 1080p VGA video output, two USB 3.1 Gen 1 Type-A (5Gbps) ports (including 1x Fast Charge port), a single USB 3.1 Gen 1 Type-C (5Gbps) port, an SD/MicroSD card reader and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 1 (5Gbps) is also known as USB 3.2 Gen 1 (5Gbps) and USB 3.0 (5Gbps).
  • Enhance Productivity
    The portable docking station offers versatile video flexibility by connecting your laptop to a 4K 30Hz HDMI monitor (4096 x 2160p) or a 1080p (60Hz) VGA monitor (1920x1080) to create a powerful workstation. For added video flexibility, the dock also supports ultra-wide monitors.
  • Connect Your Devices
    The USB-C to USB 3.1 Gen 1 hub gives you two USB-A (5Gbps) ports and one USB-C (5Gpbs) port to connect your USB devices.
  • Built-In SD Card Reader
    Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop when a power adapter is connected to the USB-C power input port. Plus, one of the USB-A (5Gbps) ports supports BC 1.2 fast charge to power your peripherals when the dock is connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB, Ethernet and video disruption when you switch power sources (USB-C power adapter to bus power).
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access with support for PXE Boot and WoL.
StarTech.com USB C Multiport Adapter, HDMI 4K 30Hz or VGA Travel Dock, 5Gbps USB 3.0 Hub (USB A / USB C Ports), 100W Power Delivery, SD/MicroSD Slot, GbE, 12" (30cm) Long Attached Cable - USB C Mini Dock - docking station - USB-C 3.2 Gen 1 - HDMI, VGA - 1GbE
Docking station
Docking Interface
USB-C 3.2 Gen 1
Video Interfaces
HDMI, VGA
5.9 cm x 1.4 cm
137 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
5.9 cm
1.4 cm
137 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 30 Hz (HDMI only) , 1920 x 1080 - 60 Hz (VGA only)
USB 3.0, USB 3.1 Gen 1, USB 3.2 Gen 1, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Slots
1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C , 1 x network - 1000Base-T - RJ-45
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 30 cm
100W power delivery, DisplayPort Alt Mode, Preboot Execution Environment (PXE) support, wake on LAN, full duplex support
USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), FCC, RoHS
Apple MacOS X 10.9 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS
Limited warranty - 3 years
Shipping Width
11 cm
Shipping Depth
5.9 cm
Shipping Height
1.4 cm
Shipping Weight
204 g
45 °C
GLR7 StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.41
GLR7 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £9.00
GLR7 StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
Device Type: Tablet
Device Type: Laptop
Device Type: Macbook
Device Type: Other
Colour: Space grey
