StarTech.com 2m USB 3.0 C Cable w/ PD (3A)
Quicklinx: CTWKWS00 Mfr#: USB315CC2M
20 In Stock
£14.59 ex VAT
£17.50 inc VAT
Charge, sync and power your USB Type-C devices. This USB 3.0 USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices. USB 3.0 is also known as USB 3.1 Gen1.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
With up to 3A (60W) of power output, you can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop.
You can also power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
With 3A of power delivery, you will be able to charge your mobile devices faster than with a regular USB-C 3.0 cable.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable, high-quality cable for all of your USB-C devices.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling. This high-quality cable is the perfect accessory to have available - it helps ensure all of your devices will be ready to use whenever you need them, while you're on the road.
StarTech.com USB 3.1 Type C Cable - 6 ft / 2m - with Power Delivery (USB PD) - Power Pass Through Charging - USB Charger (USB315CC2M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB 3.1
P/N: CDP2HVGUASPD, CDP2VGAUACP, CDP2VGAUCP, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPD3, DKT30CHPDW, DKT30CHVSDPD, DKT31CMDPHPD, HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, MST30C2HDPPD, PEXUS313AC2V, SV211HDUC, SV221HUC4K
USB-C cable
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Rated Current
3 A
Plated Connector
Nickel
Length
2 m
90 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1, RoHS, USB-IF, WEEE
CTWK StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
CTWK StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.59
CTWK StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
CTWK StarTech.com Flash Card Reader - USB-C In Stock £24.29
CTWK StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
CTWK StarTech.com 1m USB C Cable - USB 3.0 In Stock £11.26
CTWK StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
CTWK StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified In Stock £25.00
