StarTech.com Multiport Adapter + Remote
Quicklinx: F6THWS00 Mfr#: BNDDKTCHVPRS
Deliver professional presentations in any meeting or conference room. You can create a permanent or temporary workstation virtually anywhere you go and deliver professional presentations in any meeting or conference room.
This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor.
Installation is fast and easy, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port, so you can access a wired network, or connect an additional USB peripheral to your laptop.
The host laptop USB-C port must support DP Alt Mode.
The presentation remote features a sleek, ergonomic design with a wireless range of 90 feet (27 m) and includes the required batteries and a carrying case. The USB receiver is supported by generic HID drivers, ensuring it will work with virtually any Mac or Windows computer.
With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your on-screen content. It's perfect for PowerPoint presentations, websites or any other visuals you want to share with an audience.
  • Create a Mobile Workstation
    This versatile USB-C multiport adapter for laptops makes it easy to create a mobile workstation when you need it most. It features HDMI and VGA ports, so you can easily connect a 4K HDMI or a standard-definition VGA monitor. Installation is fast and easy, with native support in most operating systems. Plus, the adapter integrates a Gigabit Ethernet port and an additional USB 3.0 port, so you can access a wired network, or connect an additional USB peripheral to your laptop. The host laptop USB-C port must support DP Alt Mode.
  • Deliver Professional Presentations
    The presentation remote features a sleek, ergonomic design with a wireless range of 90 feet (27 m) and includes the required batteries and a carrying case. The USB receiver is supported by generic HID drivers, ensuring it will work with virtually any Mac or Windows computer. With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your on-screen content. It's perfect for PowerPoint presentations, websites or any other visuals you want to share with an audience. The BNDDKTCHVPRS bundle is backed by a two-year StarTech.com warranty and free lifetime technical support. Our knowledgeable Technical Advisory Team is multilingual and located at our head office.
StarTech.com USB-C Multiport Adapter with Wireless Presenter Remote - Ethernet - Portable Laptop Docking Station Bundle (BNDDKTCHVPRS) - docking station - USB-C - VGA, HDMI - GigE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
5.4 cm x 11.4 cm x 1.7 cm
192 g
Gigabit Ethernet
Power Provided
3-year warranty
Docking station
5.4 cm
11.4 cm
1.7 cm
192 g
Enclosure Colour
Video
Max Resolution Details
3840 x 2160 - 30 Hz (HDMI only) , 2048 x 1280 - 30 Hz (VGA only)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
Input Device
Remote control
1 x USB-C cable - integrated
USB powered, DisplayPort Alt Mode, auto MDIX support
FCC, RoHS, REACH
Google Chrome OS, Apple MacOS X 10.10 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Limited warranty - 3 years
Shipping Weight
300 g
5 °C
35 °C
F6TH StarTech.com USB-C Multifunction Adapter In Stock £45.80
F6TH StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £44.93
F6TH StarTech.com USB-C to VGA Adapter with PD In Stock £35.85
F6TH StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.26
F6TH StarTech.com USB-C Adapter - PD - Silver In Stock £26.25
F6TH StarTech.com USB-C Multiport Adapter - DVI In Stock £24.59
