StarTech.com MST Hub - mDP to 4x DP
Quicklinx: BFP8WS00 Mfr#: MSTMDP124DP
16 In Stock
£47.04 ex VAT
£56.44 inc VAT
Use this multi-stream transport hub to connect four DP monitors to a single mDP 1.2 port. This MST hub lets you connect four monitors to your Mini DisplayPort (mDP) 1.2 equipped Windows tablet, laptop or desktop.
The hub features a newly engineered chipset that was specifically designed and rigorously tested to resolve compatibility issues with the Microsoft Surface Pro 3.
Please note: The surface Pro 3 only supports the use of three displays in total. If more than three external monitors are attached, the built-in touch screen on your Surface will be disabled. If four monitors are attached, the fourth monitor will not display any content.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect four additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use Mini DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures that your MST hub will be compatible with virtually any television, monitor or projector. The hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTMDP123DP will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTMDP124DP supports plug-and-play installation for a hassle-free setup.
  • Increase productivity with multiple screens
  • Connect to any display
  • Configure your displays for any environment
  • Enjoy amazing video quality, without draining system resources
    MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging. Note: When using a DisplayPort 1.1 video card the MSTMDP124DP will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply. The MSTMDP124DP supports plug-and-play installation for a hassle-free setup, and is backed by a StarTech.com 3-year warranty and free lifetime technical support. Notes: MST shares 21.6 Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports, please see our guideline below for determining an ideal resolution for your setup. Certain graphics adapters have limited MST support and will only output to three displays in total. If more than three monitors are attached, the fourth will be disabled. The Surface Pro 3, Surface Pro 4, and Surface Book only support the use of three displays in total. If this device is used with the Surface Pro 3, and three external monitors, the built-in touch screen on your Surface will be disabled. Average resolution bandwidth allocation 1920x1080 (High-definition 1080p) @60hz - 22% 1920x1200 @60hz - 30% 2560x1440 @60hz - 35% 2560x1600 @60hz - 38% 3840 x 2160 (Ultra HD 4K) @30hz - 38% Note: Exceeding 100% will reduce functionality. Examples of supported resolution configurations
StarTech.com 4 Port Mini DisplayPort MST Hub - 4K 30Hz - Mini DP to DisplayPort Splitter for Multiple Monitors - mDP to DP (MSTMDP124DP) - video splitter - 4 ports
Video splitter - 4 ports
Subtype
DisplayPort
Ports
4 x DisplayPort
AC 120/230 V
20 cm x 11 cm x 2 cm
95 g
3-year warranty
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x DisplayPort
Max Resolution
3840 x 2160 @ 30 Hz
4 x DisplayPort , 1 x mini-DisplayPort
External power adapter
AC 120/230 V
FCC, RoHS
20 cm
11 cm
2 cm
95 g
Limited warranty - 3 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BFP8 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
BFP8 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
BFP8 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
BFP8 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
BFP8 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
BFP8 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
BFP8 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
BFP8 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
BFP8 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
BFP8 StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £39.71
BFP8 StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £34.58
BFP8 StarTech.com MST Hub - mDP to 2x DP In Stock £19.04
BFP8 StarTech.com MST Hub - 4-Port DisplayPort In Stock £66.85
BFP8 StarTech.com MST Hub - mDP to 4x DP In Stock £47.04
BFP8 StarTech.com mDP 1.2 to HDMI MST Hub In Stock £33.29
BFP8 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.25
BFP8 StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
BFP8 StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £31.71
BFP8 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.66
