StarTech.com MST Hub - 4-Port DisplayPort
Quicklinx: BCN6WS00 Mfr#: MSTDP124DP
Ports: 4
£69.95 ex VAT
£83.94 inc VAT
Use this multi-stream transport hub to connect four DP monitors to a single DP 1.2 port. This MST hub lets you connect four monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect four additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. This MST hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP124DP supports plug-and-play installation for a hassle-free setup.
  • Increase productivity with multiple screens
  • Connect to any display
  • Configure your displays for any environment
  • Enjoy amazing video quality, without draining system resources
    MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging. Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply. The MSTDP124DP supports plug-and-play installation for a hassle-free setup, and is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: MST shares 21.6 Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports, please see our guideline below for determining an ideal resolution for your setup. Certain graphics adapters have limited MST support and will only output to three displays in total. If more than three monitors are attached the fourth will be disabled. Average resolution bandwidth allocation: 1920x1080 (High-definition 1080p) @60hz - 22% 1920x1200 @60hz - 30% 2560x1440 @60hz - 35% 2560x1600 @60hz - 38% 3840 x 2160 (Ultra HD 4K) @30hz - 38% Note: Exceeding 100% will reduce functionality. Examples of supported resolution configurations:
StarTech.com 4-Port Multi Monitor Adapter, DisplayPort 1.2 MST Hub, 4x 1080p, Video Splitter for Extended Desktop Mode on Windows PCs Only, DP to Quad DP Monitors MST Hub - DP Multi Stream Transport Hub (MSTDP124DP) - video splitter - 4 ports
Video splitter - 4 ports
Subtype
DisplayPort
Ports
4 x DisplayPort
AC 120/230 V
20 cm x 11 cm x 2 cm
95 g
3-year warranty
P/N: SV231DPU34K, SVA5N3NEUA
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x DisplayPort
Max Resolution
3840 x 2160 @ 30 Hz
4 x DisplayPort , 1 x DisplayPort
External power adapter
AC 120/230 V
FCC, RoHS
20 cm
11 cm
2 cm
95 g
Limited warranty - 3 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BCN6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £13.40
BCN6 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £22.80
BCN6 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.58
BCN6 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
BCN6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
BCN6 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
BCN6 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
BCN6 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.87
BCN6 StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £39.71
BCN6 StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £34.58
BCN6 StarTech.com MST Hub - mDP to 4x DP In Stock £47.04
BCN6 StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
BCN6 StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £31.71
BCN6 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.66
Ports: 4
