StarTech.com MST Hub - 4-Port DisplayPort
Quicklinx: BCN6WS00 Mfr#: MSTDP124DP
Ports: 4
15 in stock
£123.83 ex VAT
£148.59 inc VAT
Use this multi-stream transport hub to connect four DP monitors to a single DP 1.2 port. This MST hub lets you connect four monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect four additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. This MST hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP124DP supports plug-and-play installation for a hassle-free setup.
  • Multi monitor adapter for Windows
    4-port DisplayPort MST hub drives up to four DP displays in extended or duplicate mode using a DP port on Windows desktop PCs or laptops.
  • Display resolution
    Quad monitor DisplayPort MST hub supports HD resolutions up to 1080p 60Hz on all four monitors.
  • Compatibility
    4-port DisplayPort MST video splitter works with laptops, computers or desktop graphics cards. Requires host system with DP 1.2/HBR2/MST or later from HP, Dell & Lenovo and AMD, NVIDIA & Intel video cards.
  • Increase productivity
    Increase productivity by extending your desktop at your workstation in the office/home office. MST technology uses your GPU/video card performance to deliver uncompressed video and use minimal system resources.
  • Easy to use
    Quad monitor adapter natively supports 4x DP monitors. Works w/Windows only and provides an easy driverless setup. Latching DisplayPort connector ensures a reliable connection and prevents accidental disconnection.
  • Convenience
    MST (multi-stream transport) hub is equipped with a built-in 7.5" (19cm) cable for video (DisplayPort) and an AC power adapter. Supports LPCM digital audio.
StarTech.com 4-Port Multi Monitor Adapter, DisplayPort 1.2 MST Hub, 4x 1080p, Video Splitter for Extended Desktop Mode on Windows PCs Only, DP to Quad DP Monitors MST Hub - DP Multi Stream Transport Hub (MSTDP124DP) - video splitter - 4 ports
Video splitter - 4 ports
Subtype
DisplayPort
Ports
4 x DisplayPort
AC 120/230 V
20 cm x 11 cm x 2 cm
95 g
3-year warranty
P/N: SV231DPU34K, SVA5N3NEUA
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x DisplayPort
Max Resolution
3840 x 2160 @ 30 Hz
4 x DisplayPort , 1 x DisplayPort
External power adapter
AC 120/230 V
FCC, RoHS
20 cm
11 cm
2 cm
95 g
Limited warranty - 3 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BCN6 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £16.09
BCN6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.37
BCN6 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £34.32
BCN6 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £27.69
BCN6 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £23.00
BCN6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.68
BCN6 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £16.34
BCN6 StarTech.com DisplayPort to DVI Active Adapter In Stock £22.56
BCN6 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.59
BCN6 StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £74.90
BCN6 StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £82.06
BCN6 StarTech.com MST Hub - mDP to 2x DP In Stock £51.10
BCN6 StarTech.com MST Hub - 4-Port DisplayPort In Stock £123.83
BCN6 StarTech.com MST Hub - 2-Port DisplayPort In Stock £61.64
BCN6 StarTech.com DisplayPort to 3x HDMI MST Hub In Stock £110.75
BCN6 StarTech.com mDP 1.2 to HDMI MST Hub In Stock £97.71
BCN6 StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £58.13
BCN6 StarTech.com DC Power Adapter - 5V, 3A In Stock £13.41
BCN6 StarTech.com USB-C to DP MST Hub - 3-Port In Stock £85.68
BCN6 StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £70.49
BCN6 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.26
Ports: 4
Stock Status: In stock
