Add 7 USB 2.0 ports to your industrial workspace, with support for DIN rail or wall-mounted installation. This sturdy, industrial grade USB 2.0 hub can be wall mounted or installed onto a DIN rail for convenient access to its 7 female USB 2.0 ports, providing a work area, server room, or industrial environment with USB 2.0 connectivity.
With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 7 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
Robust design
This USB hub features a rugged construction suitable for industrial environments, ensuring continuous operation in demanding conditions. -
Versatile connectivity
Equipped with seven Type-A USB 2.0 ports, this hub allows for easy connection of various devices, enhancing productivity. -
Flexible power options
The hub supports a nominal voltage range of DC 7 to 24 V, accommodating different power requirements for versatile applications. -
Effective status indicators
Port status and power indicators provide real-time information on the operational status, helping users manage connections efficiently.
- StarTech.com USB 2.0 Hub - 7 Port - Mountable Rugged Industrial - Self Powered USB Hub - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x USB 2.0
- Power
- DC 7 - 24 V
- 6.2 cm x 13.3 cm x 3.6 cm
- 0.5 kg
- Black
- System Requirements
- Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003
- 2-year warranty
- Designed For
- P/N: ITB20D3250, MSDREADU2OTG, USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
- Hub - 7 ports
- Enclosure Type
- DIN rail mountable
- Subtype
- USB
- Ports
- 7 x USB 2.0
- Status Indicators
- Port status, power
- 7 x USB 2.0 Type A , 1 x USB 2.0 Type B
- Voltage Required
- DC 7 - 24 V
- Black
- FCC, RoHS
- OS Required
- 6.2 cm
- 13.3 cm
- 3.6 cm
- 0.5 kg
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 9 - 95%
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £60.45 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £85.03 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £105.14 |
StarTech.com 4 Port Portable USB 2.0 Hub | In Stock | £8.59 |
StarTech.com 4Port USB C Hub C to A USB 2.0 | In Stock | £20.83 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £41.15 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £112.74 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £117.38 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £38.22 |
StarTech.com Industrial USB 3.0 5Gbps Hub | In Stock | £77.26 |
StarTech.com Industrial USB 3.0 Hub | In Stock | £297.86 |
StarTech.com Industrial USB 5Gbps Hub | In Stock | £319.95 |
StarTech.com Industrial USB 10Gbps Hub | In Stock | £175.68 |
