StarTech.com Industrial USB 5Gbps Hub
Quicklinx: HSVTWS00 Mfr#: S5G16AINDS-USB-A-HUB
Hurry, only 1 left in stock!
£314.99 ex VAT
£377.98 inc VAT
The StarTech.com 16-Port Industrial USB 5Gbps Hub is engineered to meet the demands of high-performance data environments, offering a robust solution for industrial settings. This hub is encased in a metal enclosure, providing not only durability but also ESD protection to safeguard against electrical surges and shocks. With 16 USB 3.2 Gen 1 ports, it delivers high-speed data transfer rates up to 5 Gbps, ensuring efficiency in operations.
Designed for versatility, it supports multiple mounting options including DIN rail, desktop, rack-mountable, and wall-mountable configurations, making it suitable for a variety of workspace setups. The inclusion of an external power adapter with 160 W of power ensures that all connected devices receive sufficient charging. Furthermore, its unique dual-host switch feature allows for seamless sharing between two host devices, enhancing its utility in complex setups. With a commitment to reliability, this USB hub is an essential tool for expanding connectivity in demanding industrial environments.
  • Robust design
    Encased in a durable metal housing and designed for industrial environments, this 16-Port USB hub ensures reliability and longevity with ESD protection against electrical shocks and surges.
  • Versatile mounting options
    With options for DIN rail, desktop, rack-mountable, and wall-mountable setups, this USB hub offers flexible installation to meet the demands of any workspace.
  • High-speed connectivity
    Supports USB 3.2 Gen 1 technology, allowing for data transfer rates up to 5 Gbps, making it ideal for high-speed data transmission requirements.
  • Enhanced power delivery
    Comes with an external power adapter providing 160 W of power, ensuring that connected devices are charged efficiently and reliably.
  • Dual-host switching
    Features a dual-host switch that enables two host devices to share the USB hub, enhancing peripheral sharing and flexibility in device management.
StarTech.com 16-Port Industrial USB 5Gbps Hub with Power Adapter, Metal Enclosure, Mountable, ESD Protection, Terminal Block Power, USB Charging, Dual-Host Switch - TAA - hub - 16 ports - rack-mountable - TAA Compliant
Hub - 16 ports
Enclosure Type
Rack-mountable 1U
Subtype
USB
Ports
16 x USB 3.2 Gen 1
Performance
Data transfer rate: 5 Gbps
Screw lock, over-current protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), switch button, fast charging support
USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
AC 100-240 V
1.1 kg
TAA Compliant
Hub - 16 ports
Enclosure Type
Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
Subtype
USB
Ports
16 x USB 3.2 Gen 1
Performance
1 x Genesys Logic GL3523
Status Indicators
Power, host
16 x USB 3.2 Gen 1 Type A , 2 x USB 3.2 Gen 1 Type B host , 1 x 2 pin terminal block
External power adapter
Power Provided
160 Watt - DC 24 V - 6.6 A
AC 100-240 V
158.4 Watt
Mounting screws, terminal block connector, 2 DIN-rail mounting brackets
1 x USB-A to USB-B cable - 3 m
MTBF
122,383.8 hours
EIA-310-D
TAA Compliant
1.1 kg
Shipping Width
36.8 cm
Shipping Depth
27.3 cm
Shipping Height
9.8 cm
Shipping Weight
1.8 kg
Limited warranty - 2 years , Technical support - assistance - lifetime
60 °C
5 - 95% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
75 °C
HSVT StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
