StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount
Quicklinx: 9TTZWS00 Mfr#: ARMPIVOTE
Accessory Type: Bracket
£66.67 ex VAT
£80.00 inc VAT
Mount a display on your desk surface or through a grommet, with gas-spring height adjustment and cable management. The ARMPIVOTE Articulating Monitor Arm lets you mount a display to your desk or table, with extension, tilt, pan, swivel, pivot and gas-spring height adjustments.
The desk-mount monitor arm features a gas-spring cylinder to raise or lower your display with minimal effort, plus it offers a wide range of motion on several axes. For viewing longer pages or blocks of code without scrolling, the LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 11lbs (5kg), the monitor mounting arm holds your display with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile monitor mounting solution.
StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - Monitors 12" to 34" Adjustable VESA Single Monitor Arm - Desk & Grommet Clamp - Black (ARMPIVOTE) - mounting kit - for LCD display
Mounting kit - desktop
Mounting Components
Articulating arm
Adjustments
Pan, tilt
Recommended Use
LCD display
Recommended Display Size
12"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
Material
Plastic, steel
P/N: ACCSMNT, ARMSTS, STSCART
Material
Plastic, steel
AV Furniture
Mounting kit
Mounting Components
Articulating arm
Recommended Use
LCD display
Placing / Mounting
Desktop
Cable Management
Integrated cable management
12"-24"
Adjustments
Pan, tilt
Max Load Weight
5 kg
Adjustable height, portrait to landscape movement, swivel adjustment, gas-spring technology, pivot
9TTZ StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £81.22
9TTZ StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit In Stock £88.06
9TTZ StarTech.com Sit-to-Stand Workstation In Stock £227.41
9TTZ StarTech.com USB-C Multifunction Adapter 4K In Stock £63.42
9TTZ StarTech.com Monitor and Laptop Arm In Stock £103.87
9TTZ StarTech.com USB-C Multifunction Adapter In Stock £79.80
9TTZ StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £66.98
9TTZ StarTech.com Under Desk Keyboard Tray In Stock £60.89
