StarTech.com Single Monitor Stand
Quicklinx: GLRBWS00 Mfr#: FPPNEUSTND
Accessory Type: Monitor stand, Monitor stand
More than 50 In Stock
£53.39 ex VAT
£64.06 inc VAT
This single monitor stand enables you to raise your monitor off your desk or table to save space while increasing your productivity. With its durable aluminum construction and a sturdy base (7.8"x9.4" / 200mm x 240mm), it can support VESA compatible displays up to 32" and up to 15.4lb / 7kg in weight. The power coated black semi-gloss finish on the support column provides a professional and modern look that will match your monitor and workstation. Please refer to our technical specifications section for more information on the different aspect ratios supported.
  • Adjust your monitor to the ideal position
    The free-standing monitor stand features a wide range of motion so you can position your monitor to the ideal viewing angle, allowing you to work more comfortably and reduce eye and neck strain. You can easily tilt +/-15°; swivel +/-180°; and make height adjustments to fully adjust your monitor so it can meet your ergonomic needs. With a rotating base, this monitor stand lets you swivel your display a total range of +/- 40°.
  • Easy one-touch height adjustments
    The spring-assisted monitor stand offers a total adjustment range of 10.4" to 16.3" (265mm to 415mm) from the surface or your desk. Height adjustments are easy to make with the built-in easy-access lever at the top of the stand.
  • Keep a tidy setup and protect your desk
    This monitor stand lets you keep an organized desk/workstation with the built-in cable management slot at the lower portion of the column. It is equipped with rubber anti-slip pads that will keep your desk or table surface protected from scratches or scuffs. FPPNEUSTND is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Free Standing Single Monitor Mount, Height Adjustable Monitor Stand, For VESA Mount Displays up to 32" (15lb/7kg), Ergonomic Monitor Stand for Desk, Tilt/Swivel/Rotate, Black - Universal Monitor Stand stand - adjustable arm - for Monitor - black
Stand (adjustable arm) - desktop stand
20 cm x 24 cm x 57 cm
Adjustable Height
26.5-41.5 cm
Tilt
-15° to 15°
Rotation
180°
Swivel
-40° to 40°
Adjustments
Height, tilt, swivel, rotation
3.6 kg
Recommended Use
Monitor
Recommended Display Size
Up to 32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
7 kg
Material
Aluminium
Package Content
Base, hex key (5mm), screwdriver, hex key (6mm), 4 x M4x6 screws, 4 x M4x12 screws, 4 x M5x12 screws, 4 washers
5-year warranty
20 cm
24 cm
57 cm
Adjustable Height
26.5-41.5 cm
3.6 kg
Material
Aluminium
Package Content
AV Furniture
Stand
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desktop stand
Cable Management
Integrated cable management
Up to 32"
Tilt
-15° to 15°
Rotation
180°
Swivel
-40° to 40°
Adjustments
Max Load Weight
7 kg
Dimensions & Weight Details
43.5 cm x 27.5 cm x 11.2 cm / 3.6 kg
Limited warranty - 5 years
GLRB StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £2.95
GLRB StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £68.98
GLRB StarTech.com Thin Client Mount - VESA In Stock £22.48
GLRB StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £59.47
GLRB StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
GLRB StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
GLRB StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
GLRB StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
GLRB StarTech.com Crossbar Dual Monitor Stand In Stock £85.54
