StarTech.com Monitor Arm - Heavy Duty
Quicklinx: CRY1WS00 Mfr#: ARMPIVOTHD
£72.79 ex VAT
£87.34 inc VAT
Desk-mount your monitor to save space and increase your productivity. Free up space while creating a more comfortable and productive work environment. This desk-mount monitor arm makes it easy to mount your display above your desk or table and adjust the height with one touch for ideal viewing. Its sleek silver finish enhances the aesthetics of your workspace.
This heavy-duty monitor arm helps you save space on your desk or table surface, by enabling you to securely mount a computer monitor from 13" (330 mm) to up to 32" (813 mm) in size and up to 19.8 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues.
The desk-mount monitor arm features a gas-spring cylinder that makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly at any time. It provides 13.1" (335 mm) of height adjustment to accommodate a wide range of applications. Easy one-touch height adjustment makes the monitor arm ideal for shared workstations with multiple alternating users, such as hot desks.
The full-motion articulating arm makes it easy to find the right viewing angle. You can swivel your monitor 180 degrees to share your display, while collaborating with others. The articulating arm also supports 180-degree rotation, so it's easy to switch from landscape to portrait orientation, and back again. You can also tilt your screen +90° to -90° for comfortable viewing.
The single-monitor arm is designed to ensure that mounting your VESA compatible monitor is fast and easy. It requires minimal assembly and features a detachable VESA panel that makes it simple to attach or remove your monitor. The monitor arm also offers built-in cable management that helps keep your cables out of sight to create a clean, sleek look.
StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - desk mount (adjustable arm)
Desk mount (adjustable arm)
Pan
180°
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
13"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Heavy duty aluminium
Silver
P/N: ACCSMNT
Material
Silver
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
LCD display
Cable Management
Integrated cable management
13"-32"
Pan
180°
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Adjustments
Tilt
Max Load Weight
9 kg
P/N: ACCSMNT
StarTech.com Monitor Arm - Heavy Duty Bundle deal on StarTech.com Monitor Arm - Heavy Duty
£171.96
Price Range Ex VAT: 50 - 100
