Brand
StarTech.com Monitor Arm - Heavy Duty
Quicklinx: CRY1WS00 Mfr#: ARMPIVOTHD
14 in stock
£86.44 ex VAT
£103.72 inc VAT
Desk-mount your monitor to save space and increase your productivity. Free up space while creating a more comfortable and productive work environment. This desk-mount monitor arm makes it easy to mount your display above your desk or table and adjust the height with one touch for ideal viewing. Its sleek silver finish enhances the aesthetics of your workspace.
This heavy-duty monitor arm helps you save space on your desk or table surface, by enabling you to securely mount a computer monitor from 13" (330 mm) to up to 32" (813 mm) in size and up to 19.8 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues.
The desk-mount monitor arm features a gas-spring cylinder that makes it easy to raise or lower your display. You can also adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly at any time. It provides 13.1" (335 mm) of height adjustment to accommodate a wide range of applications. Easy one-touch height adjustment makes the monitor arm ideal for shared workstations with multiple alternating users, such as hot desks.
The full-motion articulating arm makes it easy to find the right viewing angle. You can swivel your monitor 180 degrees to share your display, while collaborating with others. The articulating arm also supports 180-degree rotation, so it's easy to switch from landscape to portrait orientation, and back again. You can also tilt your screen +90° to -90° for comfortable viewing.
The single-monitor arm is designed to ensure that mounting your VESA compatible monitor is fast and easy. It requires minimal assembly and features a detachable VESA panel that makes it simple to attach or remove your monitor. The monitor arm also offers built-in cable management that helps keep your cables out of sight to create a clean, sleek look.
  • Mount your Monitor to Save Valuable Space
    This heavy-duty aluminum monitor arm helps you save space, by securely mounting a computer monitor from 13" to 34" in size and up to 19.9 lb. (9 kg) in weight. It's ideal for many different office applications, such as healthcare or financial settings, shared workspaces, or when you wish to show your display to clients or colleagues.
  • Easy One-Touch Height Adjustment
    The single monitor arm provides one-touch height adjustment, with a gas-spring cylinder that makes it easy to raise or lower your display. Adjust the tension according to the weight of your monitor, so you can re-position the monitor height effortlessly. The monitor mount provides 13.1" (335 mm) of height adjustment.
  • Adjust your Monitor Easily
    The full-motion articulating arm makes it easy to find the right viewing angle. Swivel your monitor 180 degrees to share your display. The articulating arm also supports 180-degree rotation, for landscape or portrait orientation. For comfortable viewing, tilt your screen +90 to -90 degrees.
  • Durable Construction and Easy Installation
    Made of aluminum, the single monitor mount requires minimal assembly and is easy to install with the desk clamp or grommet mount. A detachable VESA mount panel makes it simple to attach or remove your monitor. Built-in cable management helps keep your cables organized. The ARMPIVOTHD is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Desk Mount Monitor Arm, Heavy Duty Ergonomic VESA Monitor Arm, Single Display up to 9kg, Full Motion, Height Adjustable, Articulating, Aluminum, C-Clamp/Grommet, Silver - Small Footprint Design - mounting kit - adjustable arm - for LCD display - silver
Mounting kit (adjustable arm) - desk-mountable
28.4 cm x 9.6 cm x 52.9 cm
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Swivel
180°
Adjustments
Tilt
3.1 kg
Recommended Use
LCD display
Recommended Display Size
12"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Heavy duty aluminium
Silver
P/N: ACCSMNT, MONPROTECT
28.4 cm
9.6 cm
52.9 cm
3.1 kg
Material
Silver
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
12"-34"
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Swivel
180°
Adjustments
Tilt
Max Load Weight
9 kg
CRY1 StarTech.com Sit-to-Stand Workstation In Stock £224.79
CRY1 StarTech.com Thin Client Mount - VESA In Stock £24.79
CRY1 StarTech.com Under Desk Keyboard Tray In Stock £60.89
CRY1 StarTech.com Desk Mount Monitor Arm - Full Motion - Articulating - Heavy In Stock £82.91
CRY1 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £41.68
CRY1 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £44.42
CRY1 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £60.34
CRY1 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £8.28
Stock Status: In stock
