StarTech.com Mini USB Bluetooth 2.1 Adapter Class 2 EDR Wireless Network Adapter
Quicklinx: 7ZMRWS00 Mfr#: USBBT2EDR2
  • Windows 8 (32/64 bits)
Add Bluetooth 2.0 with EDR capabilities to a computer, through USB. The USBBT2EDR2 USB to Class 2 Bluetooth Adapter with EDR is a micro-sized adapter that adds Bluetooth capabilities to a computer through an available USB port, which enables you to connect to devices wirelessly, at ranges up to 20m (65ft) while consuming minimal power. Supporting the Bluetooth v2.1 specification along with Enhanced Data Rate (EDR), for transfer rates up to 3 Mbps, this adapter uses a small form factor design that makes it conveniently portable and unobtrusive when connected to a computer.
StarTech.com Mini USB Bluetooth 2.1 Adapter - Class 2 EDR Wireless Network Adapter - network adapter - USB
Network adapter
External
Interface (Bus) Type
USB
1 cm x 2 cm x 0.6 cm
2 g
Bluetooth 2.1 EDR
Bluetooth Class
Class 2
Data Transfer Rate
3 Mbps
Frequency Band
2.4 GHz
Bluetooth 2.1
Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Network adapter
External
USB
Wireless
Bluetooth 2.1 EDR
Bluetooth Class
Class 2
Data Transfer Rate
3 Mbps
Line Coding Format
DQPSK, GFSK, 8 DPSK
Frequency Band
2.4 GHz
Max Range Open Space
20 m
Status Indicators
Power, standby
USB powered
Bluetooth 2.1
Aerial
Antenna
Internal
1 x USB - 4 pin USB Type A
FCC, RoHS
1 cm
2 cm
0.6 cm
2 g
-10 °C
50 °C
