This Thunderbolt 3 docking station packs big performance into a cost-effective, compact mini dock, delivering essential connections for productivity. The bus-powered Thunderbolt 3 dock lets you connect to dual 4K HDMI displays, Gigabit Ethernet and two USB (Type-A) ports. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to HDMI dock supports 40Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources.
Connect your laptop to 2x 4K HDMI displays (up to 4096 x 2160p @ 60Hz).
To enhance your productivity, the Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support) ensures reliable wired network access. A USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, such as a flash drive, for easy file access. Connect another USB device using the USB 2.0 Type-A port.
This mini dual 4K docking station offers a versatile solution for permanent and shared office workspaces. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of (7.9 in./ 20 cm).
Create a Dual-4K 60Hz Workstation
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to HDMI dock supports 40Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources. Connect your laptop to: • 2x 4K HDMI displays (up to 4096 x 2160p @ 60Hz) -
Easy Installation & Deployment
Simply connect the?TB3 dock?to your laptop with included TB3 cable and start working immediately. No?time-consuming driver installations are required. -
The Ports You Need Most
To enhance your productivity, the Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support) ensures reliable wired network access. A USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, such as a flash drive, for easy file access. Connect another USB device using the USB 2.0 Type-A port. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com Mini Thunderbolt 3 Dock Dual 4K 6Hz HDMI - Mac/Windows Docking Station - Discontinued, Limited Stock, Replaced by TB3DKM2DPL (TB3DKM2HD) - docking station - USB-C 3.1 / Thunderbolt 3 - 2 x HDMI - GigE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- 2 x HDMI
- 6 cm x 12 cm x 1.88 cm
- 145.8 g
- Black & grey
- Networking
- Gigabit Ethernet
- Power
- Power Provided
- 3-year warranty
- Product Type
- Docking station
- 6 cm
- 12 cm
- 1.88 cm
- 145.8 g
- Enclosure Colour
- Black & grey
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
- 1 x USB-C 3.1 / Thunderbolt 3 - 24 pin USB-C , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x Thunderbolt 3 / USB-C cable - integrated - 20 cm
- USB powered, dual display support, Preboot Execution Environment (PXE) support, full duplex support, 4K Ultra HD, auto MDIX support
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 268.2 g
- 5 °C
- 35 °C
