StarTech.com Thunderbolt 3 Mini Dock - Dual Monitor DP 4K 60Hz - 1x USB/GbE
Quicklinx: G11LWS00 Mfr#: TB3DKM2DPL
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black/Silver
15 In Stock
£23.49 ex VAT
£28.18 inc VAT
N/A. This certified Thunderbolt 3 docking station is a compact mini dock, delivering essential connections for productivity. The bus-powered dock connects dual 4K DisplayPort displays, Gigabit Ethernet, and one USB-A (USB 3.2) port and for flexible set up, the attached Thunderbolt 3 cable has an extended length of (11 in./ 28 cm).
Create a Dual-4K 60Hz Workstation
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to DisplayPort dock supports 40 Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources.
Connect your laptop to:
2x 4K DisplayPort (DP) displays (up to 4096 x 2160p @ 60Hz)
Compact Size & 11-Inch Attached Host Cable
At just 2.4" x 4.9" (6.1 cm x 12.4 cm), this dock takes up minimal room on your desk and in your laptop case. The dock's 28 cm (11 inches) attached cable provides extended reach to reduce port/connector strain on MacBooks and laptops on riser stands, or if needed, offers the flexibility to position dock further away from the laptop on your desk.
The Ports You Need Most
1x USB 3.2 Gen 1 Type-A port (5 Gbps)
1x Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support)
Ideal for Power-Demanding Workstation Setups
As many high powered, later generation laptops optimally require more than 100W of power to stay charged, some users prefer to use their laptop's power adapter vs. using their docking stations to keep laptops charged.
This bus-powered TB3 mini dock is ideally suited for those users, providing full Thunderbolt 3 docking station performance and functionality, while their workstation laptops are separately charged."
The TB3DKM2DPL is Thunderbolt Certified and backed by a StarTech.com 3-year warranty and free lifetime technical support.
  • Create a Dual-4K 60Hz Workstation
    Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to DisplayPort dock supports 40 Gbps of throughput and 4K resolution at 60Hz on dual DisplayPort monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources. Connect your laptop to:
  • Compact Size & 11-Inch Attached Host Cable
  • The Ports You Need Most
    • 1x USB 3.2 Gen 1 Type-A port (5 Gbps) • 1x Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support)
  • Ideal for Power-Demanding Workstation Setups
    As many high powered, later generation laptops optimally require more than 100W of power to stay charged, some users prefer to use their laptop's power adapter vs. using their docking stations to keep laptops charged. This bus-powered TB3 mini dock is ideally suited for those users, providing full Thunderbolt 3 docking station performance and functionality, while their workstation laptops are separately charged." The TB3DKM2DPL is Thunderbolt Certified and backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com Thunderbolt 3 Mini Dock - Portable Dual Monitor w/ DP 4K 60Hz - 2X USB-A Hub (3.2/2.0), GbE - 28cm Cable - TB3 Multiport Adapter - Mac/Windows - Upgraded Version of TB3DKM2DP (TB3DKMDPL) - docking station - Thunderbolt 3 - 2 x DP - 1GbE
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
2 x DP
6.9 cm x 12.4 cm x 2.7 cm
148 g
Black & silver
Gigabit Ethernet
3-year warranty
Docking station
6.9 cm
12.4 cm
2.7 cm
148 g
Enclosure Colour
Black & silver
Video
Max Resolution Details
4096 x 2160 - 60 Hz
1 x Thunderbolt 3 - 24 pin USB-C , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB-C 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt 3 / USB-C cable - integrated - 28 cm
Preboot Execution Environment (PXE) support, 4K Ultra HD
RoHS, WEEE, RCM
Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Microsoft Windows 11, Apple MacOS X 10.10 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
13.9 cm
Shipping Depth
19.5 cm
Shipping Height
3.7 cm
Shipping Weight
300 g
5 °C
G11L StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.08
G11L StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
G11L StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.80
Device Type: Laptop
