StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card
Quicklinx: 80HMWS00 Mfr#: ST1000SMPEX
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC, Unix
Type: Network adapter
Hurry, only 1 left in stock!
£43.96 ex VAT
£52.75 inc VAT
Add a Gigabit RJ45 port through a Mini PCI Express slot. The ST1000SMPEX Mini PCI Express Gigabit Network Adapter Card adds 1000Mbps network connectivity to a Mini PCI Express (PCI Express Mini Card, Mini PCIe) enabled computer system, such as Mini-ITX motherboards. Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this Mini PCI Express Gigabit Adapter is ready to handle a wide variety of scenarios. Perfect for small form factor or embedded systems that originally lack Gigabit networking capability, or for adding a network connection without taking up a full-sized PCI Express slots, this high quality Mini PCIe Network Adapter includes a low profile/half-height bracket for additional installation options.
  • Robust network connectivity
    The StarTech.com Mini PCIe Card offers versatile network interfaces, including Ethernet 10Base-T, 100Base-TX, and 1000Base-T, ensuring compatibility with various network standards.
  • Efficient data management
    With full duplex capability, this network adapter allows simultaneous data transmission and reception, optimizing network efficiency and performance.
  • Enhanced function support
    Features like Wake On LAN, remote Wake Up, and VLAN support provide advanced networking functionalities suitable for home and enterprise environments.
  • Temperature and humidity resilience
    Operating between 0°C and 55°C with a humidity range of 5 to 95%, this card functions reliably under various environmental conditions.
  • Compliance and standards
    The card complies with FCC, RoHS, and IEEE networking standards, ensuring a safe and effective solution for users seeking certified products.
StarTech.com Mini PCIe Card - 10/100/1000Mbps RJ45 Port - IEEE 802.3 - Jumbo Frame - Network Card (ST1000SMPEX) - network adapter - PCIe Mini Card - Gigabit Ethernet
Network adapter
Plug-in card
Interface (Bus) Type
Ports
Gigabit Ethernet
4 mm x 5.1 cm x 3 cm
150 g
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
Ports
Gigabit Ethernet
Wired
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Full duplex capability, remote Wake Up, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express Mini Card - full-length
FCC, RoHS
4 mm
5.1 cm
3 cm
150 g
55 °C
5 - 95%
80HM StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £355.82
80HM StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card In Stock £43.96
80HM StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.76
80HM StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £21.64
80HM StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.93
Protocol: Gigabit Ethernet
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
