StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable
Quicklinx: 76W0WS00 Mfr#: WIRC6PATBLRL
Length: 305m
Colour: Blue
Colours:
Hurry, only 2 left in stock!
£418.20 ex VAT
£501.84 inc VAT
StarTech.com's Category 6 cable is the perfect way to connect your emerging gigabit network. Category 6 cable improves upon the Category 5e specification by providing twice the available bandwidth (up to 500Mhz), and a signal-to-noise margin improvement that is sixteen times (12dB) better than that provided by Cat 5e.
StarTech.com's Cat 6 cable is constructed by highly trained staff using top quality components that ensure the final product meets StarTech.com's strict standards for reliability. These cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
  • High-frequency performance
    Designed to support data transmission speeds for demanding computing environments, this Cat 6 Ethernet cable is tested for frequencies up to 500 MHz, ensuring optimal performance for your network applications.
  • In-wall safety
    The CM-rated design makes this 1000 ft bulk cable suitable for in-wall use, providing a secure and reliable solution for your networking infrastructure within building constructions.
  • Flexible installation
    Featuring a stranded design, this Ethernet cable offers enhanced flexibility, making it easier to install around corners and through tight spaces without compromising the integrity of the cable.
StarTech.com 1000 ft Bulk Cat6 Ethernet Cable - Stranded - CM-Rated for In-Wall Use - Cat 6 UTP Patch Cable - Blue (WIRC6PATBLRL) - bulk cable - 305 m - blue
Bulk cable - CAT 6
Unshielded twisted pair (UTP)
Stranded
Length
305 m
Blue
P/N: IES61002POE, POEINJ1G, POEINJ1GW, POEINJ4G, ST1000SMPEX, ST2000PEXPSE, ST4000PEXPSE, UPOESPLT1G, USB110EXT2
Network Cable Type
Bulk cable - CAT 6
Stranded
Length
305 m
Blue
Up to 500 MHz
Length: 305m
Colour: Blue
