StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card
Quicklinx: 80HMWS00 Mfr#: ST1000SMPEX
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC, Unix
Type: Network adapter
£33.11 ex VAT
£39.73 inc VAT
Add a Gigabit RJ45 port through a Mini PCI Express slot. The ST1000SMPEX Mini PCI Express Gigabit Network Adapter Card adds 1000Mbps network connectivity to a Mini PCI Express (PCI Express Mini Card, Mini PCIe) enabled computer system, such as Mini-ITX motherboards. Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this Mini PCI Express Gigabit Adapter is ready to handle a wide variety of scenarios. Perfect for small form factor or embedded systems that originally lack Gigabit networking capability, or for adding a network connection without taking up a full-sized PCI Express slots, this high quality Mini PCIe Network Adapter includes a low profile/half-height bracket for additional installation options.
StarTech.com Mini PCIe Card - 10/100/1000Mbps RJ45 Port - IEEE 802.3 - Jumbo Frame - Network Card (ST1000SMPEX) - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
Ports
Gigabit Ethernet
4 mm x 5.1 cm x 3 cm
150 g
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
Ports
Gigabit Ethernet
Wired
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Full duplex capability, remote Wake Up, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express Mini Card - full-length
FCC, RoHS
4 mm
5.1 cm
3 cm
150 g
55 °C
5 - 95%
80HM StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £242.31
80HM StarTech.com 1 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £6.09
80HM StarTech.com 100 ft Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.27
80HM StarTech.com 1 ft Cat 6 Green Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £2.69
80HM StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card In Stock £8.74
80HM StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card In Stock £33.11
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
