Add a Gigabit RJ45 port through a Mini PCI Express slot. The ST1000SMPEX Mini PCI Express Gigabit Network Adapter Card adds 1000Mbps network connectivity to a Mini PCI Express (PCI Express Mini Card, Mini PCIe) enabled computer system, such as Mini-ITX motherboards. Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this Mini PCI Express Gigabit Adapter is ready to handle a wide variety of scenarios. Perfect for small form factor or embedded systems that originally lack Gigabit networking capability, or for adding a network connection without taking up a full-sized PCI Express slots, this high quality Mini PCIe Network Adapter includes a low profile/half-height bracket for additional installation options.
- StarTech.com Mini PCIe Card - 10/100/1000Mbps RJ45 Port - IEEE 802.3 - Jumbo Frame - Network Card (ST1000SMPEX) - network adapter - PCIe Mini Card - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express Mini Card
- Ports
- Gigabit Ethernet
- 4 mm x 5.1 cm x 3 cm
- 150 g
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- 1 Gbps
- Status Indicators
- Link/activity
- Full duplex capability, remote Wake Up, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express Mini Card - full-length
- FCC, RoHS
- OS Required
- 4 mm
- 5.1 cm
- 3 cm
- 150 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable | In Stock | £355.82 |
StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card | In Stock | £43.96 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.34 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £21.30 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £21.08 |
