Connect your VGA monitor to a Mini DisplayPort equipped computer.
The MDP2VGA Mini DisplayPort VGA Adapter Cable offers a cost-effective VGA/Mini DisplayPort link, letting you connect a VGA computer monitor to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
Easily connect your Mini DisplayPort computer to a VGA display
The mDP to VGA adapter lets you connect your Mini DisplayPort laptop, desktop or tablet to a VGA display. The adapter is compatible with mDP ports as well as Thunderbolt 1 and Thunderbolt 2 I/O ports, and supports plug-and-play connectivity ensuring a hassle-free setup. -
Works with legacy VGA monitors
The Mini DisplayPort adapter makes your mDP computer fully compatible with existing VGA monitors or projectors in your home or around your office. The VGA connector features nuts that mate with the screws on standard VGA cables, to ensure your video cable won't get disconnected. -
Designed for maximum portability
The Mini DisplayPort to VGA converter maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your Surface Pro or Ultrabook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office. -
Crystal-clear picture quality
With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition. The MDP2VGA is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com Mini DisplayPort to VGA Video Adapter Converter - video adapter - Mini DisplayPort to HD-15 (VGA) - 13 cm
- Video adapter
- Active adapter
- Length
- 13 cm
- Connector
- Mini DisplayPort - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female (output)
- DisplayPort 1.2
- Black
- Designed For
- P/N: DKT31CMDPHPD, DP2MDPMF3, DP2MDPMF6IN
- Video adapter
- Jacket Material
- Plastic
- Active adapter
- Length
- 13 cm
- Black
- 3.56 cm
- 1.9 cm
- 28 g
- Connector
- DisplayPort 1.2, FCC, RoHS, WEEE, REACH, RCM
- Shipping Width
- 2 cm
- Shipping Depth
- 2.2 cm
- Shipping Height
- 0.6 cm
- Shipping Weight
- 37 g
- Designed For
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £6.11 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £18.06 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £15.08 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £9.00 |
