StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200
Quicklinx: 95QCWS00 Mfr#: MDP2VGA2
27 In Stock
£14.18 ex VAT
£17.01 inc VAT
Connect a Mini DisplayPort 1.2-equipped PC or Mac to a VGA Monitor or Projector. The MDP2VGA2 Mini DisplayPort to VGA converter enables you to connect your Mini DisplayPort video source (Laptop, Macbook, Ultrabook etc.) to a VGA monitor or projector, saving the expense of upgrading to a Mini DisplayPort compatible display. The mDP adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
With a small foot print and no external power adapter this mDP to VGA adapter ensures maximum portability making it an ideal laptop accessory.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
  • Versatile connectivity
    This adapter allows for a simple connection between Mini DisplayPort enabled devices and VGA monitors, facilitating various display configurations.
  • High-resolution support
    With a maximum output resolution of 1920 x 1200, this adapter provides sharp image quality for a wide array of multimedia applications.
  • Active adapter technology
    Utilizing active adapter technology ensures that video signals maintain their integrity for reliable performance, essential for presentations.
  • Compliance and safety
    Built in accordance with FCC and RoHS standards, the adapter promotes a safer work environment while ensuring quality performance.
StarTech.com Mini DisplayPort to VGA Adapter - DisplayPort 1.2 - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA (MDP2VGA2) - video adapter - Mini DisplayPort to HD-15 (VGA) - 22 cm
Video adapter
Active adapter, 1920 x 1200 (WUXGA) support
Length
22 cm
Connector
Mini DisplayPort - male
Connector (Second End)
15 pin HD D-Sub (HD-15) - female
Displayport 1.2/Thunderbolt
3-year warranty
Video adapter
Length
22 cm
3.5 cm
0.8 cm
27 g
Connector
Displayport 1.2/Thunderbolt, FCC, RoHS
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.8 cm
Shipping Weight
36 g
3-year warranty
95QC StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £6.04
95QC StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £17.93
95QC StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £14.18
