Brand
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White
Quicklinx: 81T7WS00 Mfr#: MDP2VGAW
Length: 17cm
13 in stock
£15.04 ex VAT
£18.04 inc VAT
Connect a VGA display to a Mini-DisplayPort -equipped PC or Mac computer. The MDP2VGAW Mini-DisplayPort to VGA Adapter (White) offers an easy-to-use VGA/Mini-DisplayPort link that enables you to connect a VGA computer monitor to a device with a Mini-DisplayPort output (such as a laptop video out port) or video card.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a Mini DisplayPort video source to a VGA monitor without sacrificing video quality.
  • Easily connect your Mini DisplayPort computer to a VGA display
    The mDP to VGA adapter lets you connect your Mini DisplayPort laptop, desktop or tablet to a VGA display. The adapter is compatible with mDP ports as well as Thunderbolt 1 and Thunderbolt 2 I/O ports, and supports plug-and-play connectivity ensuring a hassle-free setup.
  • Works with legacy VGA monitors
    The Mini DisplayPort adapter makes your mDP computer fully compatible with existing VGA monitors or projectors in your home or around your office. The VGA connector features nuts that mate with the screws on standard VGA cables, to ensure your video cable won't get disconnected.
  • The perfect travel companion for your MacBook with Mini DisplayPort
    With its all-white design, this Mini DisplayPort video adapter is the perfect travel accessory for your MacBook with mDP. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office. While the adapter looks great next your Mac it also works with any Mini DisplayPort computer, such as your Windows laptop.
  • Crystal-clear picture quality
    With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition. The MDP2VGAW is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com Mini DisplayPort to VGA Adapter - White - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA Converter (MDP2VGAW) - video converter - white
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
4.5 cm x 18 cm x 1.5 cm
Enclosure Colour
White
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female
Active cable (signal regeneration)
- 12 cm
FCC, RoHS, WEEE, DisplayPort 1.1a
4.5 cm
18 cm
1.5 cm
31 g
Enclosure Colour
White
Limited warranty - 3 years
60 °C
40 - 85%
81T7 StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £19.65
81T7 StarTech.com 6 ft Mini DisplayPort to VGA Cable - M/M In Stock £32.38
81T7 StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £15.04
81T7 StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £20.07
81T7 StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £18.82
81T7 StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £22.04
81T7 StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.39
81T7 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £25.26
81T7 StarTech.com mDP to VGA Adapter with Audio In Stock £18.03
Length: 17cm
Stock Status: In stock
