StarTech.com 6' mDP to VGA Cable with Audio
Quicklinx: BM0QWS00 Mfr#: MDP2VGAAMM2M
Select:
  • 2m
Connect the audio and video from your Mini DisplayPort Mac or PC directly to a monitor. Now you can organize your workspace with less mess than ever before.
This unique 6-foot Mini DisplayPort to VGA adapter cable features a built-in audio port, which enables you to connect a VGA monitor as well as speakers to your Mini DisplayPort (mDP) equipped desktop computer.
Remove the cable clutter from your desk. With the built-in audio port you no longer need to run a separate audio cable from your monitor or speakers directly to your desktop or laptop computer. Simply plug the audio cable from your speakers into the adapter cable for a simple and tidy solution.
In order to use the audio function of the adapter, it needs to be powered through USB. Simply connect a Micro-USB cable into the adapter from your computer, monitor or USB grommet in order to provide the necessary power.
The adapter guarantees you always have all of the connections you need. If the audio port on your computer is damaged or blocked, this adapter cable ensures you still have sound available for watching video presentations, listening to music while you work or chatting with your colleagues over Skype.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, and supports resolutions up to 1920x1200 (WUXGA).
StarTech.com 6 ft / 2m Mini DisplayPort to VGA Adapter Cable with Audio - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB (power only) - 5 pin Micro-USB Type B (power only)
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male , 1 x audio line-in - mini-phone 3.5 mm - female , 1 x USB (power only) - 5 pin Micro-USB Type B (power only) - female
Active cable (signal regeneration), Thunderbolt port compatible
1 - 2 m
FCC, RoHS, WEEE
104 g
Enclosure Colour
Limited warranty - 3 years
70 °C
BM0Q StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £6.11
BM0Q StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.08
BM0Q StarTech.com DP to VGA Adapter with Audio In Stock £19.30
