StarTech.com Mini DisplayPort to HDMI Video Adapter Converter
Quicklinx: 6LCNWS00 Mfr#: MDP2HDMI
Hurry, only 1 left in stock!
£10.12 ex VAT
£12.14 inc VAT
The StarTech.com MDP2HDMI Mini DisplayPort HDMI Adapter Cable offers a cost-effective HDMI/Mini DisplayPort link, letting you connect an HDMI display to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility.
MDP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
  • Simple to use, small form factor converter makes Mini DisplayPort backwards compatible with your existing HDMI display or projector
  • No installation software or drivers required providing a simple plug and play solution
  • Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
  • Easy to use cable, no software required
Applications
  • Ideal for digital entertainment centers, home offices, business conference rooms and trade show displays
  • Keep your existing HDMI monitor to be used with your new Mini DisplayPort device
  • Ideal for using your HDMI monitor as a secondary display
StarTech.com Mini DisplayPort to HDMI Adapter - 1080p - Thunderbolt Compatible - Mini DP Converter for HDMI Display or Monitor (MDP2HDMI) - adapter - 76.2 mm
Cable
Adapter - DisplayPort / HDMI
Length
76.2 mm
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
P/N: DP2MDPMF3, DP2MDPMF6IN
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
Length
76.2 mm
Connector
19 pin HDMI Type A - female
RoHS
40 mm
1.5 cm
20 g
Limited warranty - 3 years
6LCN StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.48
6LCN StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £10.12
6LCN StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio In Stock £67.72
6LCN StarTech.com 3 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k In Stock £12.97
6LCN StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k In Stock £23.78
6LCN StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £10.37
6LCN StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £13.11
6LCN StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £12.40
6LCN StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £16.09
6LCN StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.42
6LCN StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.72
6LCN StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £17.82
6LCN StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £16.97
6LCN StarTech.com 6ft mDP to HDMI cable - 4K In Stock £16.25
6LCN StarTech.com 3ft mDP to HDMI cable - 4K In Stock £13.65
6LCN StarTech.com Mini DisplayPort to HDMI - 4K In Stock £21.48
Stock Status: In stock
