Eliminate clutter by connecting your PC or Mac directly to an HDMI display, using this short cable. This 3-foot Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft mDP to HDMI cable (MDP2HDMM2MB) enabling you to choose the right cable length for your custom installation needs.
Astonishing picture quality
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video. -
Hassle-free setup
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling. -
Clutter-free installation
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, we also offer a 6 ft mDP to HDMI cable (MDP2HDMM2MB) enabling you to choose the right cable length for your custom installation needs. The MDP2HDMM1MB is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com Mini DisplayPort to HDMI converter cable - 3 ft (1m) - mDP to HDMI adapter with built-in cable - (M / M) Ultra HD 4K (MDP2HDMM1MB) - adapter cable - DisplayPort / HDMI - 1 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Length
- 1 m
- Black
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - male
- DisplayPort 1.2
- 4K support
- 3-year warranty
- Cable Type
- Adapter cable 4K support
- Interface Supported
- DisplayPort 1.2
- Length
- 1 m
- HDCP compliant, DPCP compliant
- Black
- Connector
- 19 pin HDMI Type A - male
- FCC, RoHS
- Limited warranty - 3 years
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter | In Stock | £11.67 |
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter | In Stock | £18.78 |
StarTech.com 3ft DP to HDMI cable - 4K | In Stock | £14.50 |
StarTech.com 6ft mDP to HDMI cable - 4K | In Stock | £15.81 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £15.82 |
StarTech.com 3ft mDP to HDMI cable - 4K | In Stock | £14.50 |
StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 3m | In Stock | £16.81 |
StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 5m | In Stock | £18.00 |
StarTech.com Mini DisplayPort to HDMI Adapter - 1080p | In Stock | £11.85 |
