The StarTech.com MDP2HDMI Mini DisplayPort HDMI Adapter Cable offers a cost-effective HDMI/Mini DisplayPort link, letting you connect an HDMI display to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility.
MDP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
- Simple to use, small form factor converter makes Mini DisplayPort backwards compatible with your existing HDMI display or projector
- No installation software or drivers required providing a simple plug and play solution
- Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
- Easy to use cable, no software required
Applications
- Ideal for digital entertainment centers, home offices, business conference rooms and trade show displays
- Keep your existing HDMI monitor to be used with your new Mini DisplayPort device
- Ideal for using your HDMI monitor as a secondary display
Easily connect your Mini DisplayPort computer to an HDMI display
The mDP to HDMI adapter lets you connect your Mini DisplayPort laptop, desktop or tablet to an HDMI display. The adapter is compatible with mDP ports as well as Thunderbolt 1 and Thunderbolt 2 I/O ports, and supports plug-and-play connectivity ensuring a hassle-free setup. -
Works with HD TVs
The Mini DisplayPort adapter features a female HDMI connector that supports 7.1 audio, making your mDP computer fully compatible with an HDMI television or projector in your home or around your office. -
Designed for maximum portability
The Mini DisplayPort to HDMI converter maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your Surface Pro or Ultrabook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office. -
Crystal-clear picture quality
With support for video resolutions up to 1080p, you'll be surprised at the picture spectacular picture quality this adapter provides. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition. The MDP2HDMI is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com Mini DisplayPort to HDMI Adapter - 1080p - Thunderbolt Compatible - Mini DP Converter for HDMI Display or Monitor (MDP2HDMI) - adapter - DisplayPort / HDMI - 76.2 mm
- Cable
- Adapter - DisplayPort / HDMI
- Length
- 76.2 mm
- Black
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - female
- 3-year warranty
- Designed For
- P/N: DP2MDPMF3, DP2MDPMF6IN
- Cable Type
- Adapter
- Interface Supported
- Length
- 76.2 mm
- Black
- Connector
- 19 pin HDMI Type A - female
- RoHS
- 40 mm
- 1.5 cm
- 20 g
- Limited warranty - 3 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.49 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter | In Stock | £11.67 |
StarTech.com 3 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k | In Stock | £13.86 |
StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k | In Stock | £27.17 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £10.59 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £5.85 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.52 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.88 |
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter | In Stock | £18.78 |
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter | In Stock | £21.14 |
StarTech.com 3ft mDP to HDMI cable - 4K | In Stock | £14.53 |
StarTech.com Mini DisplayPort to HDMI - 4K | In Stock | £24.91 |
