Connect a DVI display to a Mini DisplayPort equipped PC or MAC . The StarTech.com MDP2DVI Mini DisplayPort DVI Adapter Cable offers a cost-effective DVI/Mini DisplayPort link, letting you connect a DVI computer monitor to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility. MDP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
- StarTech.com Mini DisplayPort to DVI Adapter - 1920x1200 – Thunderbolt 2 – mDP to DVI Converter for Your Mini DP MacBook or PC (MDP2DVI) - DVI adapter - 10.2 cm
- DVI adapter
- Length
- 10.2 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DP2MDPMF3, DP2MDPMF6IN, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
- DVI adapter
- Length
- 10.2 cm
- Black
- Connector
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.66 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £10.74 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £26.12 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £24.58 |
StarTech.com 3 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k | In Stock | £13.83 |
StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k | In Stock | £25.38 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White | In Stock | £10.89 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.45 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £16.03 |
StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M | In Stock | £13.40 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £10.96 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £14.81 |
StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black | In Stock | £24.75 |
