StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 – White
Quicklinx: 964QWS00 Mfr#: MDP2DVIMM6WS
Connect a Mini DisplayPort-equipped PC or MAC to a DVI display, with an active 6ft cable. The MDP2DVIMM6WS 6ft active Mini DisplayPort to DVI adapter cable lets you directly connect your Mini DP video source (Laptop, Macbook, Ultrabook etc.) directly to a DVI monitor or projector, saving the expense of additional adapters. The converter features a stylish white design, that is well-suited for connecting Mac computers.
For guaranteed compatibility with virtually any Mini DisplayPort output the active Mini DP to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the MDP2DVIMM6WS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 2560x1600.
StarTech.com 6 foot Mini DisplayPort to DVI Active Adapter Converter Cable - 6 ft (1.8m) Active mDP to DVI M/M Cable - 1920x1200 - White (MDP2DVIMM6WS) - DisplayPort cable - 1.8 m
DisplayPort cable
Active cable (signal regeneration)
Length
1.8 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
White
3-year warranty
DisplayPort cable
Length
1.8 m
White
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
964Q StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
964Q StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.80
964Q StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.88
964Q StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.79
964Q StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.76
964Q StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £8.16
