Connect a DVI Display to a Mini DisplayPort Video Source. The MDP2DVI3 Mini DisplayPort to DVI Adapter lets you connect your Mini DisplayPort video source (desktop PC, laptop, etc.) to a DVI monitor, projector, or display, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports display or projector resolutions up to 1920x1200 (WUXGA) and is compliant with HDCP standards.
MDP2DVI3 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Convenient connectivity
This adapter features a male Mini DisplayPort connector on one end and a female 24+5 pin combined DVI connector on the other, allowing easy connection between different display types. -
Robust video support
Capable of handling video resolutions up to 1920 x 1200 and 1080p, this adapter ensures that users can enjoy high-definition video output without compromise.
- StarTech.com Mini DisplayPort to DVI Adapter - 1920x1200 - 1080p - Dongle - Monitor Adapter - Mini DisplayPort Adapter - Mini DP to DVI (MDP2DVI3) - DVI adapter - 17 cm
- DVI adapter
- Length
- 17 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- Black
- 3-year warranty
- DVI adapter
- Length
- 17 cm
- Black
- Connector
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.63 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £10.73 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £24.49 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £10.60 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £14.88 |
