Connect your DVI monitor to a Mini DisplayPort-equipped computer using a single cable.
The MDP2DVIMM6 6-foot Mini DisplayPort to DVI Cable is a cost-effective Mini DisplayPort to DVI link that lets you connect a DVI monitor to a PC or Mac with a Mini DisplayPort output - saving the expense of upgrading the monitor for compatibility. This all-in-one, easy to use Mini DisplayPort/DVI cable requires no additional converters or adapters, and no driver or software installation.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
MDP2DVIMM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
- StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M - MDP to DVI Cable - MiniDP to DVI - Mini DP to DVI Converter (MDP2DVIMM6) - DisplayPort cable - 1.8 m
- DisplayPort cable
- Length
- 1.8 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Length
- 1.8 m
- Black
- Connector
- 24+1 pin digital DVI - male
- FCC, RoHS
- 3-year warranty
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.55 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £23.23 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £9.75 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.53 |
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black | In Stock | £18.47 |
