Connect your Mini DisplayPort video source to a DVI-D display.
The MDP2DVID Mini DisplayPort to DVI-D Dual-Link adapter lets you connect your Mini DisplayPort video source (Macbook, Macbook Pro, Macbook Air, etc.) to any DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor. The Mini DisplayPort adapter offers an active conversion, which is powered by a single USB port and is able to handle full dual-link resolutions (up to 2560x1600). Use it to mirror your display to another monitor, or extend your desktop to increase your workspace.
- StarTech.com Mini DisplayPort to DVI Dual-Link Active Adapter - USB Powered - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 2560 x 1600
- 1 x DisplayPort input - Mini DisplayPort , 1 x DVI-D output - 24+1 pin digital DVI , 1 x USB - 4 pin USB Type A
- 16 cm x 20.8 cm x 1.2 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 2560 x 1600
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x DVI-D output - 24+1 pin digital DVI - female , 1 x USB - 4 pin USB Type A - male
- USB powered
Video Output
- Supported Display Graphics
- WUXGA (1920 x 1200), 2560x1600
- FCC, RoHS
- 16 cm
- 20.8 cm
- 1.2 cm
- 119 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 70 °C
- 10 - 85% (non-condensing)
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.80 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.80 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.37 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £17.08 |
