Connect your mini DisplayPort Device to a DisplayPort, HDMI or DVI Display, with this Compact, All-in-One Adapter. The MDP2DPDVHD mini DisplayPort to DisplayPort, DVI or HDMI Multifunction Adapter converts a mini DisplayPort (mDP) input to DisplayPort, DVI or HDMI output signals - all in a single compact adapter. This multifunction adapter offers the unique ability to connect almost any display to your mini DisplayPort equipped PC or Mac, providing the perfect solution for business environments that have mixed display hardware - saving the expense of purchasing new displays for compatibility. A plug-and-play solution that requires no software or drivers, this versatile mDP adapter offers a quick and simple installation for the utmost convenience. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
- StarTech.com Travel A/V adapter - 3-in-1 Mini DisplayPort to DisplayPort DVI or HDMI converter (MDP2DPDVHD) - adapter - DisplayPort / HDMI / DVI - 15 cm
- Cable
- Adapter - DisplayPort / HDMI / DVI
- Length
- 15 cm
- Black
- Connectors
- Mini DisplayPort - male
- Connectors (Second End)
- DVI-D - female , HDMI - female , DisplayPort - female
- 3-year warranty
- Cable Type
- Adapter
- Interface Supported
- Length
- 15 cm
- Black
- Connectors
- 24+1 pin digital DVI - female , 19 pin HDMI Type A - female , 20 pin DisplayPort - female
- Plug and Play, FCC, RoHS
- Limited warranty - 3 years
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.35 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £20.15 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £9.27 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.23 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.03 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £7.58 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £31.29 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £8.96 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £8.19 |
StarTech.com DP to HDMI or VGA Converter | In Stock | £17.49 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.52 |
