StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200
Quicklinx: 95QCWS00 Mfr#: MDP2VGA2
More than 50 in stock
£15.04 ex VAT
£18.04 inc VAT
Connect a Mini DisplayPort 1.2-equipped PC or Mac to a VGA Monitor or Projector. The MDP2VGA2 Mini DisplayPort to VGA converter enables you to connect your Mini DisplayPort video source (Laptop, Macbook, Ultrabook etc.) to a VGA monitor or projector, saving the expense of upgrading to a Mini DisplayPort compatible display. The mDP adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
With a small foot print and no external power adapter this mDP to VGA adapter ensures maximum portability making it an ideal laptop accessory.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
StarTech.com Mini DisplayPort to VGA Adapter - DisplayPort 1.2 - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA (MDP2VGA2) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
3.5 cm x 22 cm x 0.8 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female
Active cable (signal regeneration)
- 18 cm
FCC, RoHS, WEEE
3.5 cm
22 cm
0.8 cm
25 g
Enclosure Colour
Limited warranty - 3 years
70 °C
10 - 85%
95QC StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.80
95QC StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.18
95QC StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.06
95QC StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £19.18
95QC StarTech.com 6 ft Mini DisplayPort to VGA Cable - M/M In Stock £33.02
95QC StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
95QC StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £13.44
95QC StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £19.54
95QC StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £18.34
95QC StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £23.56
95QC StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.04
95QC StarTech.com mDP to VGA Adapter with Audio In Stock £18.03
Price Range Ex VAT: 0 - 50
