StarTech.com Kit for Surface Pro 4 / 3 - mDP to VGA or HDMI - USB GbE
Quicklinx: 9NYCWS00 Mfr#: MSTP3MDPUGBK
Enhance your Microsoft Surface Pro 4, Surface Pro 3 or Surface 3 by adding HDMI or VGA video outputs, Gigabit Ethernet and an extra USB port. Get more from your Microsoft Surface Pro 4 (backward compatible with Surface Pro 3, Surface 3 and Surface Pro 2) by adding HDMI and VGA video compatibility as well as wired network connectivity.
You can maximize the versatility of your Microsoft Surface by ensuring that you can connect to virtually any monitor, projector or television. This accessory kit ensures that you're ready to connect to any HDMI or VGA display using the Mini DisplayPort output on your Surface Pro 4, Surface Pro 3 or Surface 3 making it the perfect solution when you're traveling between boardrooms, home and remote offices, trade-shows, hotels and conference centers.
Get the speed and reliability of a hardwired Ethernet connection with your Surface Pro 4. This Surface accessory kit includes a reliable USB 3.0 to Gigabit Ethernet adapter, which adds wired network support that's ideal for BYOD hot-desking, or use as an on-the-go dock solution to enhance your workstation.
The adapter also includes an extra USB 3.0 port built-in, so you can add a USB peripheral device, such as a flash drive for added storage, or a mouse for increased control.
Your Microsoft Surface is one of the most versatile and portable computers in the world. Don't be tied down by accessories that require an external power adapter, or a bulky housing. This kit adds four essential ports (HDMI, VGA, GbE and USB 3.0) from three compact adapters that don't require external power, so they easily fit into your laptop bag or carrying case.
  • Connect your surface to virtually any display
  • Hard-wire your network connection
    Get the speed and reliability of a hardwired Ethernet connection with your Surface Pro 4. This Surface accessory kit includes a reliable USB 3.0 to Gigabit Ethernet adapter, which adds wired network support that's ideal for BYOD hot-desking, or use as an on-the-go dock solution to enhance your workstation. The adapter also includes an extra USB 3.0 port built-in, so you can add a USB peripheral device, such as a flash drive for added storage, or a mouse for increased control.
  • Maximize portability
StarTech.com 3-in-1 Accessory Kit for Surface and Surface Pro 4 - mDP to HDMI / VGA - USB 3.0 GbE - Works with Surface Pro 3 and Surface 3 (MSTP3MDPUGBK) - notebook accessories bundle
Notebook accessories bundle
Package Content
Mini DisplayPort to VGA adapter, Mini DisplayPort to HDMI Adapter, USB 3.0 Gigabit Ethernet Adapter
Microsoft Surface Pro 3, Pro 4
Package Content
FCC, RoHS
Limited warranty: - 2 years
9NYC StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.74
9NYC StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.08
