StarTech.com mDP to HDMI or VGA Converter
Quicklinx: B146WS00 Mfr#: MDP2HDVGA
40 in stock
£18.11 ex VAT
£21.73 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to an HDMI or VGA display. This travel adapter lets you connect your mDP enabled Ultrabook or laptop computer to any VGA or HDMI display. The 2-in-1 Mini DisplayPort adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
Why carry multiple adapters when you only need one? Instead of keeping two different adapters on-hand, the MDP2HDVGA mDP travel adapter offers both VGA and HDMI outputs, so you'll be able to connect from your laptop mDP output to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p you can convert a Mini DisplayPort video source to HDMI or VGA without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
The 2-in-1 converter is compatible with the Intel Thunderbolt port on your computer and installs easily with no software or drivers required.
StarTech.com Mini DisplayPort to HDMI and VGA - 2 in 1 Travel Adapter - Mini DisplayPort to VGA Adapter - Mini DP to HDMI Dongle - Monitor Adapter (MDP2HDVGA) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
10.5 cm x 25 cm x 2.36 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
FCC, RoHS
10.5 cm
25 cm
2.36 cm
Enclosure Colour
Limited warranty - 3 years
60 °C
10 - 85%
B146 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.10
B146 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £10.13
B146 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.06
B146 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.45
B146 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £24.42
B146 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £33.01
B146 StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £24.42
B146 StarTech.com mDP to HDMI or VGA Converter In Stock £18.11
B146 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
B146 StarTech.com DP to HDMI or VGA Converter In Stock £15.43
B146 StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £27.07
B146 StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz In Stock £65.66
Stock Status: In stock
