Connect your DisplayPort equipped computer system to an HDMI or VGA display. This DisplayPort to HDMI + VGA travel adapter lets you connect your DP enabled Ultrabook or laptop computer to any VGA or HDMI display.
Why keep several adapters when you only need one? With this single DisplayPort tor VGA and HDMI adapter you can rest assured that your computer can interface with any modern boardroom or classroom display. It's the ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p, you can convert your DisplayPort video source to HDMI or VGA without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. This convenient construction ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter.
With this adapter you can walk into virtually any boardroom ready to present, making a great first impression and saving you the embarrassment of having to rummage through your bag looking for the right connector. Plus, the 2-in-1 converter installs easily with no software or drivers required.
- StarTech.com 2 in 1 Displayport Adapter - DisplayPort to HDMI or VGA - DisplayPort Adapter - 1920x1200 - Travel Adapter (DP2HDVGA) - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 5.8 cm x 19 cm x 1.3 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 5.8 cm
- 19 cm
- 1.3 cm
- 37 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £20.15 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £9.27 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.55 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.03 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £8.95 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £31.29 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £8.19 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £13.32 |
StarTech.com DP to HDMI or VGA Converter | In Stock | £16.21 |
StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video | In Stock | £20.48 |
