This Mini DisplayPort to Dual-Link DVI adapter lets you connect your Mini DisplayPort video source (such as any of your MacBook or Microsoft Surface Pro devices with mDP) to any DVI display, including televisions and Apple Cinema Display HD, saving the cost of upgrading to a Mini DisplayPort capable monitor.
With its compact, lightweight design, the Mini DisplayPort to DVI-D Adapter offers a convenient travel accessory to carry with your Surface Pro or Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this monitor adapter perfect for BYOD (Bring Your Own Device) applications at the office.
As well, the DVI converter is powered by a single USB port, eliminating the need for additional cords or chargers.
The Mini DisplayPort to DVI adapter offers an active conversion and can handle full dual-link resolutions (up to 2560 x 1600) with the ability to mirror your display or extend your desktop to increase your workspace. The adapter supports plug-and-play connectivity, ensuring a hassle-free setup.
Maximum Portability
With its compact, lightweight design, the Mini DisplayPort to DVI-D Adapter offers a convenient travel accessory to carry with your Surface Pro or Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this monitor adapter perfect for BYOD (Bring Your Own Device) applications at the office. As well, the DVI converter is powered by a single USB port, eliminating the need for additional cords or chargers. -
Uncompromised Quality and Convenience
The Mini DisplayPort to DVI adapter offers an active conversion and can handle full dual-link resolutions (up to 2560 x 1600) with the ability to mirror your display or extend your desktop to increase your workspace. The adapter supports plug-and-play connectivity, ensuring a hassle-free setup. MDP2DVID2 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com Mini DisplayPort to Dual-Link DVI Adapter - USB Powered - Dual Link Connectivity - Black - DVI Active Display Converter (MDP2DVID2) - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI (Dual-Link): 2560 x 1600 / DVI (Single-Link): 1920 x 1200
- 1 x DisplayPort input - Mini DisplayPort , 1 x USB 2.0 - 4 pin USB Type A , 1 x DVI-D output - DVI-D
- 6.39 cm x 9.32 cm x 2.25 cm
- Length
- 35.8 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 2560 x 1600 at 60 Hz
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x USB 2.0 - 4 pin USB Type A - male , 1 x DVI-D output - DVI-D - female
- USB powered
- Plug and Play, RoHS, WEEE, FCC, RCM, DisplayPort 1.2a
- 6.39 cm
- 9.32 cm
- 2.25 cm
- Length
- 35.8 cm
- 118 g
- Shipping Weight
- 128 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 10 - 85% (non-condensing)
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.13 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £22.37 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.82 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £10.73 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.32 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.99 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £25.41 |
