Connect a DVI display to a Mini DisplayPort equipped PC or MAC . The StarTech.com MDP2DVI Mini DisplayPort DVI Adapter Cable offers a cost-effective DVI/Mini DisplayPort link, letting you connect a DVI computer monitor to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility. MDP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
Durable construction
Built with high-quality materials, this adapter ensures longevity and reliable performance, making it suitable for everyday use. -
Compact design
The lightweight and small form factor of this adapter makes it easy to carry and use, perfect for traveling professionals. -
Wide compatibility
This adapter is designed to work with Mini DisplayPort devices, offering versatility for both MacBook and PC users.
- StarTech Mini DisplayPort to DVI Adapter - 1920x1200 – Thunderbolt 2 – mDP to DVI Converter for Your Mini DP MacBook or PC (MDP2DVI) - DVI adapter - 10.2 cm
- DVI adapter
- Cable Length
- 10.2 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DP2MDPMF3, DP2MDPMF6IN, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
- DVI adapter
- Cable Length
- 10.2 cm
- Black
- Connector
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £23.80 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £9.88 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.79 |
