Add the fast performance of an M.2 NVMe SSD to your desktop computer or server by converting the drive through a U.2 (SFF-8639) compatible interface on your motherboard. This PCI Express M.2 to U.2 adapter makes it easy to install an M.2 PCIe NVMe SSD into your desktop PC or server, and connect to the drive through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. It supports one M.2 PCIe NVMe SSD (M-Key), providing a cost-effective way to add M.2 NVMe performance to your computer or server through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter works with all desktop PCs and servers that have an available drive bay or a U.2 (SFF-8639) compatible host interface. The adapter card is OS independent, so there are no drivers or software required for installation.
Upgrade your system cost-effectively
The M.2 to U.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. -
Easy installation
The M.2 to U.2 adapter works with all desktop PCs and servers that have an available drive bay or a compatible host interface.
- StarTech.com M.2. PCI-e NVMe to U.2 (SFF-8639) Adapter - Not Compatible with SATA Drives or SAS Controllers - For M.2 PCIe NVMe SSDs - PCIe M.2 Drive to U.2 Host Adapter - M2 SSD Converter (U2M2E125) - interface adapter - M.2 Card - U.2
- Interface adapter - external
- Bus Type
- U.2
- Red
- Expansion Bays
- 1 x internal - M.2 2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- 7 cm x 10 cm x 0.7 cm
- 33.4 g
- 2-year warranty
- M.2
- Host Bus
- U.2
- Red
Storage Controller
- Interface
- M.2 Card
- Supported Devices
- Solid state drive
- 1
- Bays
- 1 x M.2 Card - key M slot (supports M-key or B+M-key modules) (internal)
- Connections
- 1 x Ultra M.2 Card - U.2 (SFF-8639)
- Included Accessories
- 4 x screws
- Supports NVM Express
- FCC, RoHS, WEEE
- Limited warranty - 2 years
- 7 cm
- 10 cm
- 0.7 cm
- 33.4 g
- 5 °C
- 50 °C
- 15 - 90%
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £29.24 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.52 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £17.99 |
StarTech.com Tool-Less 2B Mounting Bracket | In Stock | £6.47 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.59 |
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.56 |
StarTech.com 2.5" SSD/HDD Mounting Bracket | In Stock | £4.21 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £31.05 |
StarTech.com M.2 to U.2 Adapter | In Stock | £22.89 |
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £44.81 |
StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance | In Stock | £63.05 |
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure | In Stock | £46.39 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £43.99 |
StarTech.com M.2 to U.3 Adapter/Converter | In Stock | £29.75 |
