Get ultra-fast data access by adding an NVMe U.2 SSD to your computer. This U.2 to PCIe adapter lets you add a high-speed, U.2 NVMe SSD to a PC with an available PCI Express expansion slot. You can mount the PCIe U.2 drive directly onto the adapter, giving you an easy and convenient way to improve your system performance and expand overall internal storage.
Boost your system speed and performance
The expansion card lets you take full advantage of the fast performance and compact size of PCIe U.2 internal solid-state drives. The adapter connects directly to your computer motherboard to support an NVMe U.2 PCIe-based SSD through ultra-fast PCIe. With the U.2 PCIe-based drive in place, the adapter gives your computer a significant speed boost. -
Easy to install
The expansion card is equipped with a full-profile bracket and doesn't require an adapter cable for installation, this helps to reduce clutter and simplifies system builds.
- StarTech.com U.2 to PCIe Adapter - x4 PCIe - For 2.5" U.2 NVMe SSD - SFF-8639 PCIe Adapter - U.2 SSD - PCIe SSD - U.2 drive (PEX4SFF8639) - interface adapter - Ultra M.2 Card - PCIe 3.0 x4
- Interface adapter - plug-in card
- Bus Type
- PCIe 3.0 x4
- Red
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- Ultra M.2 Card
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- 2.2 cm x 16.5 cm x 12.2 cm
- 65 g
- 2-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, U2M2E125
- 2.5"
- Hard Drive Maximum Height
- 15 mm
- Host Bus
- PCIe 3.0 x4
- Red
Storage Controller
- Interface
- Ultra M.2 Card
- Supported Devices
- Solid state drive
- 1
- 1 x Ultra M.2 Card - U.2 (SFF-8639)
- Connections
- 1 x PCIe 3.0
- Supports NVM Express
- Limited warranty - 2 years
- 2.2 cm
- 16.5 cm
- 12.2 cm
- 65 g
- 5 °C
- 50 °C
- 15 - 90%
- Designed For
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £16.17 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £20.58 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £47.26 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £31.73 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £19.59 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £32.73 |
StarTech.com M.2 to U.2 Adapter | In Stock | £24.14 |
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £46.55 |
StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure | In Stock | £48.32 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £45.45 |
StarTech.com U.3 to PCIe Adapter Card | In Stock | £34.34 |
