StarTech.com M.2 to U.2 Adapter
Quicklinx: D0JZWS00 Mfr#: U2M2E125
Type: Interface Adapter
Compatibility: PC
Interface: M.2 Card
More than 50 In Stock
£23.11 ex VAT
£27.73 inc VAT
Add the fast performance of an M.2 NVMe SSD to your desktop computer or server by converting the drive through a U.2 (SFF-8639) compatible interface on your motherboard. This PCI Express M.2 to U.2 adapter makes it easy to install an M.2 PCIe NVMe SSD into your desktop PC or server, and connect to the drive through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. It supports one M.2 PCIe NVMe SSD (M-Key), providing a cost-effective way to add M.2 NVMe performance to your computer or server through an available U.2 (SFF-8639) compatible interface on your motherboard.
The M.2 to U.2 adapter works with all desktop PCs and servers that have an available drive bay or a U.2 (SFF-8639) compatible host interface. The adapter card is OS independent, so there are no drivers or software required for installation.
  • Upgrade your system cost-effectively
  • Easy installation
    The M.2 to U.2 adapter works with all desktop PCs and servers that have an available drive bay or a compatible host interface.
StarTech.com M.2. PCI-e NVMe to U.2 (SFF-8639) Adapter - Not Compatible with SATA Drives or SAS Controllers - For M.2 PCIe NVMe SSDs - PCIe M.2 Drive to U.2 Host Adapter - M2 SSD Converter (U2M2E125) - interface adapter - M.2 Card - U.2
Interface adapter - external
Bus Type
U.2
Red
Expansion Bays
1 x internal - M.2 2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Supported Devices
Solid state drive
Max Storage Devices Qty
1
7 cm x 10 cm x 0.7 cm
33.4 g
M.2
Host Bus
U.2
Red
Storage Controller
M.2 Card
Supported Devices
Solid state drive
1
Bays
1 x M.2 Card - key M slot (supports M-key or B+M-key modules) (internal)
1 x Ultra M.2 Card - U.2 (SFF-8639)
4 x screws
Supports NVM Express
FCC, RoHS, WEEE
7 cm
10 cm
0.7 cm
33.4 g
5 °C
50 °C
15 - 90%
D0JZ StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
D0JZ StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
D0JZ StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
D0JZ StarTech.com Tool-Less 2B Mounting Bracket In Stock £6.49
D0JZ StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
D0JZ StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.64
D0JZ StarTech.com M.2 to U.2 Adapter In Stock £23.11
D0JZ StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £40.35
D0JZ StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £64.63
D0JZ StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £45.80
D0JZ StarTech.com M.2 to U.3 Adapter/Converter In Stock £30.49
Compatibility: PC
Interface: M.2 Card
