StarTech.com M.2 RAID Controller Card PCIe
Quicklinx: C193WS00 Mfr#: PEXM2SAT3422
Type: Storage controller (RAID)
Compatibility: PC
Hurry, only 2 left in stock!
£59.28 ex VAT
£71.13 inc VAT
Add two Next Generation Form Factor M.2 SSDs and two SATA ports to your computer through PCI Express. This M.2 SSD RAID controller card lets you install two M.2 NGFF (Next Generation Form Factor) drives in your desktop computer. The card also features two SATA III (6Gbps) ports and supports hardware RAID. Now, you can merge the speed and compact size of M.2 solid state drives (SSD) with the storage capacity of traditional hard disk drives (HDD).
This M.2 controller card lets you take advantage of the size and performance benefits of NGFF SSDs. M.2 drives are smaller than typical platter drives or mSATA-based SSDs, so you can install them in small form-factor PCs and servers, or in tighter areas within your computer case.
When you couple the card with an M.2 drive, you can give your computer's performance a noticeable speed boost. By installing your operating system on the M.2 drive, you'll have faster access to the files you commonly use, and you can continue to use your higher-capacity platter HDD for bulk storage.
Due to their performance and size advantages, M.2 drives are commonly used in laptops. If your laptop has failed but its M.2 drive is functional, then this card can help with data recovery. Once the M.2 drive is installed and the data recovery is complete, you can continue to use the drive for storage and backup purposes.
If you need a scalable, internal storage solution that you can count on, then this card can help. It supports a range of RAID configurations (RAID 0, 1, and 10), giving you multiple ways to expand your storage, improve your computer's performance, or to create data redundancy backups.
Because the M.2 card supports port multiplication, you can connect up to four drives to one of the card's SATA ports. With a built-in port multiplier, you can install up to seven drives (two M.2 SSDs, five SATA drives) in your computer through this single drive controller.
You can rest assured that your M.2 SATA drives are compatible with the card. It supports the most common drive sizes, including 22110, 2280, 2260, 2242 and 2230. For more versatility, the card also supports hybrid drives.
  • Leverage the size and speed of M.2 drives
    This M.2 controller card lets you take advantage of the size and performance benefits of NGFF SSDs. M.2 drives are smaller than typical platter drives or mSATA-based SSDs, so you can install them in small form-factor PCs and servers, or in tighter areas within your computer case. When you couple the card with an M.2 drive, you can give your computer's performance a noticeable speed boost. By installing your operating system on the M.2 drive, you'll have faster access to the files you commonly use, and you can continue to use your higher-capacity platter HDD for bulk storage.
  • Peace of mind, with simple and cost-effective data recovery
  • Build a high-performance RAID array
  • Connect even more drives with port multiplication
  • Supports a wide range of drives
    You can rest assured that your M.2 SATA drives are compatible with the card. It supports the most common drive sizes, including 22110, 2280, 2260, 2242 and 2230. For more versatility, the card also supports hybrid drives. The PEXM2SAT3422 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 2x M.2 NGFF SSD RAID Controller Card plus 2x SATA III Ports - PCIe - Two Slot PCI Express M.2 RAID Card plus Two SATA Ports (PEXM2SAT3422) - storage controller (RAID) - M.2 Card / SATA 6Gb/s - PCIe 2.0 x2
Storage controller (RAID) - plug-in card
Bus Type
PCIe 2.0 x2
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
2 cm x 18 cm x 12 cm
100 g
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
M.2
Host Bus
PCIe 2.0 x2
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
RAID Level
Marvell 88SE9230
2 x M.2 Card - M.2 Card (internal)
Low-profile bracket, 2 x M.2 mounting screws
Support port multiplier
FCC, RoHS
2 cm
18 cm
12 cm
100 g
5 °C
50 °C
20 - 80% (non-condensing)
C193 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.17
C193 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £20.58
C193 StarTech.com M.2 RAID Controller Card PCIe In Stock £59.28
C193 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £19.59
C193 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £29.84
C193 StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £21.56
C193 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £32.73
C193 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £135.99
Compatibility: PC
